THE WASP
146 replies to this topic
#106 Scott.Tamson
Scott.Tamson
  • 750 posts
  • Local Club: None..on here alottt though :)
Posted 02 September 2008 - 11:39 PM
Congrats on passing MOT >_< Have Fun.
#107 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 September 2008 - 12:14 PM
Nice one on the MOT, it's screaming for a black grille!
#108 Bristolboy
Bristolboy
  • 291 posts
Posted 03 September 2008 - 03:10 PM
That looks absolutely fantastic :mmkay:
All we need off you now is a long driving video :- lol
Bb
#109 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 09 September 2008 - 10:53 PM
more pics more pics more pics
and a vid would be great too!!
#110 jordan-will
jordan-will
    Starting My Mini Up
  • 1 posts
Posted 06 January 2009 - 09:35 PM
Fantastic build mate.
To go with Honda engine and the yellow paint, get some "jordan" stickers as in the ones on the jordan civics. Put them just before the rear arch.
#111 Dan515
Dan515
  • 41 posts
Posted 09 January 2009 - 07:12 PM
thats a nice mini you have there
i was wondering what type them arches are?
#112 Boots
Boots
  • 151 posts
  • Local Club: North Devon Mini Club
Posted 19 March 2009 - 12:57 PM
There miglia arches, but i cut and shapped them a bit! there will be a update soon! :D
Steve
#113 daveeeeee
daveeeeee
  • 684 posts
Posted 20 March 2009 - 03:24 PM
awesome project i really like it!
thought i might do something similar with my boot floor, is it fairly strong?
#114 Prawn
Prawn
  • 938 posts
Posted 20 March 2009 - 04:48 PM
Seeing as I've got the mk2 version of steves boot, I can answer that!
it's very strong indeed, it seems to take the weight of steves 12 gallon tank perfectly well, and it's seam welded into the original shell.
Steves floor was done by Mintec Mini Spares of Newton Abbot, his was the first done by them, and mine was the second. If you look in the back of miniworld, Mintec have an add in the traders section.
Here's my boot floor when it was first finished:
Here it is with the tank in place:
There's still loads of clearence under the floor for the exhaust, the level basicly follows out from the base of the seat squab.
Steves project is awesome, when we took it to combe back in september it got SO much attention, I cant wait to see it finished and back on the road again!
#115 mattdc2r
mattdc2r
  • 1,296 posts
  • Local Club: Not yet!
Posted 22 March 2009 - 10:25 PM
What an amazing build. Nice work :thumbsup:
#116 daveeeeee
daveeeeee
  • 684 posts
Posted 03 April 2009 - 09:06 PM
thanks prawn, looks awesome!
#117 Boots
Boots
  • 151 posts
Posted 22 May 2009 - 10:27 AM
Finally a update for you guys :P :) As prawn mentiond, we took the car to castlecombe last september for the miniworld event as a test run! Found a few issues that I have been sorting out ever since!
1. Rear wheels scrub back of arches on hard cornering (i was told they were smoking)
2. My brakes were RUBBISH, i think this was because i was using the wrong size master!
3. Rear Hudersfield beam isnt very good so many points are wrong with it, so that needs replacing with another beam that has caster and camber settings!
4. Understeer - realy need some adjustable lower arms!
I now have a fiberglass Curley Switch Pod dash, so i had the original rails put back in
Decided to have the bulk head box reduced to give me more room behind the dash and to allow for demister vents
Front coilover shock mounts beefed up!
Front end modified to cover the subframe properly!
Rear Arch mods!
Engine back in so radiator and servo can be tweeked a bit!
Radiator mounted about 1" lower than before, not sure yet, but it mite just sit under the slam panel now :thumbsup:
Standard servo master cylinder and dizzy dont like each other much, so have seperated them a bit so ther is good clearance, its a working progress still tho!
Choped the parcel shelf out, will be replaced with a bolt in sheet of ally or Carbon Fiber just to save a bit of weight also means i can mount speakers to a MDF board much easyer if neeeded!
And this is the rear lower engine steady bracket, its actually tacked on now!
New engine mounts (85a Grade Inovative Mounts) should stop all that engine movement!
Watsons Beam fitted, this is 100% adjsutable ( track,castor,camber,toe in,toe out)
no pics of the beam its self :) however afew with the car rolling again!
n/s shows crazy camber and o/s showing normal ish!
last but not least!
Im having my boot floor re-worked as i have a new Custom 7.5ltr tank, similar shape to prawns, but the boot floor will house the tank and also alow for more room for the back box, that will be the next update, hopfully within the next few weeks!
Steve
#118 Boots
Boots
  • 151 posts
Posted 22 May 2009 - 10:29 AM
Oh and there is a vidclip or 2 of the mini on the track on prawns camera, so if we pester him lots, he mite just upload them :P
#119 Ro8bieg
Ro8bieg
  • 1,581 posts
  • Local Club: Fylde Mini Club
Posted 22 May 2009 - 10:50 AM
That front end looks fantastic now! great project.
#120 Prawn
Prawn
  • 938 posts
Posted 22 May 2009 - 12:17 PM
7.5 gallons dear boy! 7.5 litres would give you a range of about 50 miles!
my tank is 6.9 gallons, and hides entirely below the line of the boot lid.
Car's looking awesome those steve! let's hope you can mount the arches a bit lower on the shell this time so they don't make it look so high!
Cant wait to see it when I get home :P
