Grotbag...
Posted 15 November 2004 - 10:39 PM
Don't know what to do with it/him/her yet, got a fer dodgy bits of rot, the boot's had smack and bent the floor pan, but the engine run and seems quite solid in the mechanical dept..
Will know more on Friday when get to pull a few bits of..
PS, It's a 85 Mayfair with the most horrific Beige Velour interior... :sick: but is completely original ( apart from the spots ) with black bumpers handles etc...
Posted 15 November 2004 - 10:47 PM
I had an 85 mayfair, 3 layers of cills! not a good year
Posted 16 November 2004 - 09:09 AM
Edited by GuessWorks, 28 July 2005 - 01:11 PM.
Posted 16 November 2004 - 12:29 PM
Posted 16 November 2004 - 12:47 PM
Been sat on the drive for 18 month, both doors are shot, must admit my first comment was, "seen better in a scrap yard", but I think most of that is because it's been sat around.. cob webs, faded paint dust, damp etc..
Posted 16 November 2004 - 01:45 PM
Posted 16 November 2004 - 10:53 PM
probelm im thinking if is if i brake down, i have my 4x4 to come and get me, BUT how..
now what i want it your bar lol
na how does it atach?
i no you have a teoing eye about there but what do you put into it,
never realy thort about it realy, hence ive never looked or asked the question.
Posted 17 November 2004 - 08:48 AM
http://www.machinema...asp?p=051510006
With this you do need someone in the second vehicle to steer....
If you want to di it single handed you'll need an A frame towing system like this...
They're not cheap, but are not that difficult to make either, if you can weld, I know some one who's made one, and at some stage will be pinching it to measure up and make one for the local club..
Posted 17 November 2004 - 10:24 AM
How do you attach a towing eye to a mini then? because i have been doing something a bit bad and towing mine with the Tie rod on the offside, i know it is bad, but there is seriously no where on my mini to tow from. don't want to chain it round the subframe, or what alot of people do round the regplate brackets and it lasts about 5 seconds!
Them bars are good aswel, as the person in the car being towed doesn't need to brake, only steer.
Can be a bit short tho, and when you are being towed by a large vehicle, you cannot see any upcoming hazards!!
good investment if you ask me!
Rich
Posted 17 November 2004 - 12:30 PM
http://www.minispare....aspx?pid=33804
or make your own !
Posted 17 November 2004 - 04:27 PM
"Grotbag" great name.
do you have a spare £6k?
theres the opportunity of mighty mini racing or alike.
and hey the mini forum could sponcer you!
(members put money into it not just down to the admin)
Posted 17 November 2004 - 04:47 PM
That type of towing eye (with a stud) is what I have fitted and is damn hard to use.
The thread isn't normal, it's metric ultra fine or something and it's hard getting hold of high tensile nuts to fit it. You can now get a type of towing eye with a tube nut instead which the existing screw threads into. Much better and what I'll buy in future.
Towing A frames are what we use at work for car stuff a lot of the time. Pretty cool things (unless you have a 2cv or hydraulic suspension). Crunching the front valence doesn't matter to us, it's only money!
Posted 17 November 2004 - 05:25 PM
So that could be why it doesn't have one in the jack bag,
When i go to the garage and order something, i always say that i have a 97' so they don't go ordering SPI parts!
I don't know what you meant about the
I wouldn't mind getting one sorted, as i have got to tow it again to rover when my new ECU arrives.
is it a simple jobby to sort out?
Rich
Posted 17 November 2004 - 06:07 PM
Posted 19 November 2004 - 07:38 PM
Anyway, as I was saying, got her home and decided to give it a cut an a polish just to see what it should look like..
And tweaked the engine just enough to get a smooth idle, has a little blow in the exhaust but sounds and runs like a fairly tight motor, rear brakes are locked on so will have to pull them off, and will have to pull the boot out where it's bee pushed in... ( The boot in the piccies is the one of the Thirty I had )
Piccies follow....
