Replacing points system with electronic ignition distribution?
Posted 01 May 2007 - 01:07 PM
Posted 01 May 2007 - 02:22 PM
http://www.minispare...s...;ty=fi&rt=1
Posted 01 May 2007 - 03:05 PM
You cannot use a Sports Coil with the Lumenition unit while the Pertronix/Aldon unit can be used with an Aldon brand upgraded coil designed for this purpose but still not the Lucas Sports Coil, although you really don't need to anyway. The spark energy generated by an electronic ignition system is much higher than that of a contact breaker system even using a standard coil.
Lumenition Magnetronic from Mini Spares
Posted 01 May 2007 - 03:30 PM
Yes, Pertronix/Ignitor can be used with ballasted ignition... however, it still needs a full 12V supply. If you have a ballasted ignition system you cannot connect the Pertronix "red" wire to the coil (+) for power, you'll need a separate switched supply as Dan mentioned.
Posted 01 May 2007 - 04:04 PM
Posted 01 May 2007 - 04:36 PM
No, the Ignitor module safely uses any supply voltage between 6 and 16 volts. The Magnetronic is much more fussy and requires 12 to 14v. However as I said I would always give the unit a dedicated supply.
Maybe there really is a difference between the Aldon and Pertronix versions in this respect.
Both of these units are the least technical, simplest to install electronic ignition systems available. You really do just fit them in place of the points, connect up the wires and then completely forget they exist.
A Sports Coil gives an increase in spark energy when using conventional contact breaker ignition. Essentially it is a better made, higher grade transformer than the standard coil. They are not needed if you choose to fit electronic ignition as I said above. Points ignition generally supplies around 25,000 volts so people fit a Sports Coil to bring it up to around 32,000v. Electronic ignition can easily supply 35,000 volt sparks from a standard coil which is plenty hot enough.
Posted 01 May 2007 - 06:06 PM
Then it’s just a case of setting the timing and away you go, never to be messed with again, well only to replace the cap and rotor arm when they need it.
Posted 01 May 2007 - 06:16 PM
Posted 01 May 2007 - 06:22 PM
Posted 01 May 2007 - 06:24 PM
(which eventually court fire)
Gotta love French parts! Distributor on fire!
It will work, it just won't be in tune for the whole range of the engine.
Posted 01 May 2007 - 06:45 PM
See the manual at:
http://www.pertronix...nitor12vneg.pdf
particularly the second and third questions on sheet 2 regarding low voltage operation and the schematics for connection when using a ballasted ignition system.
I have a few U.S. acquaintances who have had problems with Pertonix only to learn after contacting Tech Support that they needed to supply the Ignitor module with a full +12V.
Posted 02 May 2007 - 09:28 AM
http://www.aldonauto.co.uk/
Follow the links to the Ignitor (it's one of those incredibly annoying websites that doesn't have individually addressed pages to link to) and it shows the unit spec and lists 6 to 16 volts.
It seems there is a difference between the Aldon and Pertronix versions of the unit afer all. As I said though I would always supply it directly because it will upset the voltage in the ballast circuit if it is fitted to the ballast.
I also notice from that sheet that Pertronix are quite specific that it needs a conventional coil. Aldon say that it can be used with their own upgraded coils.
Edited by Dan, 02 May 2007 - 09:29 AM.
Posted 02 May 2007 - 12:07 PM
Posted 02 May 2007 - 04:51 PM
You can use the Pertronix Ignitor with performance coils if you're careful. (Of course, they promote their own line of "Flamethrower" coils for use with the Ignitor). One of my Canadian Mini owner friends has had lengthy telephone conversations with their tech support group to learn what the current limits are. He's now running a high-performance, lower-resistance coil just within the limits of what they said he could get away with. Prior to contacting Pertronix he'd burnt out one or two Ignitors that he thought would be OK with his choice of coils.
Are you in Canada too? Where abouts?
Posted 02 May 2007 - 08:20 PM
