1978 Clubman - C16se
#31
Posted 03 August 2005 - 08:12 AM
who did you order the paint from and how late is it?
#32
Posted 03 August 2005 - 08:24 AM
Thanks for saying it looks good, it'll look a lot better when its the right colour! :tongue:
#33
Posted 03 August 2005 - 10:04 PM
the doors, bonnet and bootlid are all in primer now, pretty much ready for topcoat once they have a rub down.
I wanted to keep it quiet but I can't help it! Painted the engine bay in the topcoat! and all the door closures! Which meant I could refit the master cylinders (after painting them) and all the brake pipes!
Just the front subframe to put on now and I have myself a rolling shell....
I'm aiming for an MOT on the 18th August, not long to transform a car from a half painted shell to a road legal car, but, here's hoping!
#34
Posted 04 August 2005 - 09:35 AM
#35
Posted 04 August 2005 - 10:18 AM
Cut the seat away in sections, coming in at 45deg to the seat, so you can see where to stop as you come up to the heelboard. Be wary of catching the heelboard with the grinder. Then smooth the edges with the grinder to get a good finish. We also fitted triangulation pieces to the b pillars/sills to retain the rigidity, as the companion bins help to support the seat and b pillars, and floor.
Fitting the roll cage will also help to introduce strength to the area too.
#36
Posted 04 August 2005 - 05:38 PM
I really want those, though. What size wheels are you going with.
#37
Posted 05 August 2005 - 11:19 AM
I used a hand drill to cut the holes in the arches, and then a coping saw and round/square files to get the slits needed where the arches go over the seams.
Then I offered the arch up to the body, and used an automatic centre punch to mark the hole for the front screw on each arch. Having drilled a hole, I then used a steel self tapper to 'cut' the hole in the panel (stainless self tappers aren't strong enough to cut the hole), then fitted one stainless self tapper.
Once one screw was in I just marked each one, took the arch off, drilled it, fitted the screw, marked next one, took arch off, drilled, fitted etc etc until they were all done. It took about 2 hours, and I was lucky as the arches will not require a waft over with any paint as they weren't damaged during the fitting.
Oh, and my quickrack arrived today! That means I can fit the subframe this weekend! Woohoo!!!
(oh yeah sorry, I'm using 10x5" wheels)
Edited by Minis84, 06 August 2005 - 09:55 AM.
#38
Posted 06 August 2005 - 09:43 AM
#39
Posted 06 August 2005 - 09:54 AM
The engine bay is also painted in the final colour too, but I haven't got any pics of that just yet, i'll try to get some later on.
#40
Posted 07 August 2005 - 10:57 AM
Good luck finnishing it it will be worth all the trouble when finnished
#41
Posted 07 August 2005 - 12:00 PM
Then I fitted the front subframe, with its new solid mounts, and then put the Cooper 'S' disc assy's with 4-pots back on. I replaced the CV gaitors and re-greased the CV's too, to make sure.
Then I fitted the braided hoses, and fitted the rest of the new brake pipes, and secured them to the subframe.
And then I had some lunch :tongue:
So now I have a car with a braking system thats ready to bleed! Only thing is, I haven't got an eezibleed, and Dad has gone to get some scaffolding from yorkshire, so I've got no-one to pump the pedal for me! :nugget:
Oh well, I'll go and get the wiring loom and fit that I reckon - and I need to find that new starter solenoid that I have.....
#42
Posted 07 August 2005 - 02:03 PM
I also found the solenoid, which is nice and shiny, and has a push button in the middle, which means I can crank the engine from the engine bay rather than the key providing the ignition is on. All good!
Now I've got to go shopping because i'm cooking dinner tonight.
Quite why I'm giving you a full run down of my weekend I don't know, but never mind eh!
(oh yeah, some photos to follow tonight)
#43
Posted 07 August 2005 - 09:57 PM
And just wondering have you fed the wiring before youve sprayed the inside and hopeing to mask it or have you sprayed it now
#44
Posted 08 August 2005 - 09:35 PM
pics to follow shortly, I took some tonight, just gotta get them off the digital camera.
#45
Posted 08 August 2005 - 09:48 PM
