1978 Clubman - C16se
#286
Posted 26 July 2006 - 09:37 PM
just a rough run down of parts and prices would be good i have looked at the 16v minishop but i'm not sure what i'd need and wouldnt need
great project hope i could make as good a progress as you!
keep it up
#287
Posted 27 July 2006 - 08:57 AM
The most expensive item for the whole conversion is the subframe. This, along with all the necessary components, i.e driveshafts, bottom arms and tie rods, engine mounts and mounting bolts, comes to just over £1500 with the VAT.
Then you need to source an engine and gearbox, with wiring loom and ECU etc. I paid fairly big money for mine from the 16V Mini Shop, but its a known runner and in good nick. There's a C16SE engine on eBay at the moment for a buy it now of £55, but you have to remove it yourself (it will come with all ancillaries though!). So you could obviously get one quite cheaply, and gearboxes aren't expensive. You need to make sure you get the right ratio gearbox (an F15 TD gearbox is good).
Then its stuff like radiator, fuel tank, fuel lines, brake pipes etc. My radiator is from a Mk2 Astra 1300, and cost just over £40. The fuel tank is SPi and I got it for nothing (but expect to pay around £20 for one). You need a Vauxhall Bosch in-tank pump if you're using the SPi/MPi tank, this will set you back around £35 for a second hand one. Fuel lines aren't expensive (just get 8mm copper pipe), and neither are brake pipes and a flaring kit (budget £50 for the lot).
You need to make sure your brakes and suspension are up to the job of coping with the extra torque, so budget for upgrades if you're not sure of their capability.
Then it's a case of all the little things, finishing off bits like hoses, clips, nuts and bolts etc. The Mini gauges can be used with the Vauxhall wiring but it would be worth fitting some auxillary gauges too.
Hope that helps!
Tom
#288
Posted 27 July 2006 - 06:57 PM
Not gonna get my hopes up but I reckon the engine could be in by this weekend
#289
Posted 27 July 2006 - 07:36 PM
#290
Posted 27 July 2006 - 08:27 PM
thanks lee
#291
Posted 28 July 2006 - 06:05 PM
#292
Posted 29 July 2006 - 06:11 PM
Well I was right not to get my hopes up, the engine is still sat waiting to go in the car! However I've managed to finish off the rear end of the car, in that the rear screen and side windows are back in, speaker wires and fuel pump wiring has been run through the roof to the front of the car, and the new battery cable is in place and the distribution box on the front bulkhead is fitted, along with the right end on the battery cable. Oh, and the new shortened handbrake cable is fitted, and the handbrake is adjusted, all working fine
Gonna try to persuade the brakes to bleed tomorrow morning if possible, then over the next week I'll rebuild the engine with the new parts and aim to get it in and plumbed up as much as possible by next weekend. Here's hoping anyway!
#293
Posted 30 July 2006 - 11:18 AM
#294
Posted 01 August 2006 - 09:19 PM
So not much more until that's ready to go in (the gearbox is all sorted ready to bolt to the engine).
The fuel tank and fuel pipes etc are all in and sorted:
And the rear subframe/shocks etc back on:
Today my birthday present from Jenny arrived, a nice shiny Alpine MP3 headunit, for plenty of choons when going to Germany, and just a few more things to do before I drop the engine in.
About another 2 weeks I reckon!
#295
Posted 01 August 2006 - 09:53 PM
#296
Posted 01 August 2006 - 10:26 PM
#297
Posted 08 August 2006 - 06:35 PM
#298
Posted 10 August 2006 - 07:23 AM
Anyway, this weekend I was quite busy, I don't know what fitting a 2L 16V engine is like, because a 1.6 8V is bad enough!:
Its certainly a squeeze, but it went in
Since then I've fitted the radiator, and now I'm just waiting on hoses and pipework for the plumbing. Then I've got to do wiring and sort out the gear linkage, but its getting there now. Oh yeah and the exhaust manifold and system is fully on, the 1-7/8" Maniflow system that I had went on with no modifications needed at all, which was nice
Not long now, MOT on the 19th I reckon.
#299
Posted 10 August 2006 - 08:01 AM
Matt
#300
Posted 10 August 2006 - 08:16 AM
16XE next thing to do once I've saved up enough money for TB's and I've had my fun with this one!! 100 ft/lb and 100bhp should keep me happy for a while!!
