1978 Clubman - C16se
536 replies to this topic
#241 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 17 May 2006 - 06:09 PM
Wow, things are moving quick here aren't they!! :ph34r:
#242 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 17 May 2006 - 06:12 PM
christ, that was fast!
best of luck
#243 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 17 May 2006 - 07:47 PM
When are you getting your new engine? And where from? Im presuming being on 10's your going to be using the diesel box on it?
How come you sold your engine so fast, im guessing it went all in one go?
#244 rob mini
rob mini
  • 1,420 posts
Posted 17 May 2006 - 10:31 PM
right then tom im watchin a few bits :lol: good luck and talk about not hanging about!
#245 Purple Tom
Purple Tom
  • 4,921 posts
Posted 17 May 2006 - 10:50 PM
Should be getting the engine within the next 2 or 3 weeks with any luck. I think for the time being I'm going to use the F13 gearbox, which is the standard Astra box, with slightly lower ratio's (more chance of wheelspin). If that proves too much for the 10's then I'll fit the F15 'box from the Corsa TD.
The gearbox sold within 2 hours of my mate knowing it was for sale, and the engine went the next day, as a complete unit, got excellent $$ for it too :lol:
I'll keep you informed as to how its all going!
I'm also going to be building a new centre console at the same time, to conceal the Vauxhall gear selector mechanism, and also to house a head unit and two speakers, and provide good ventilation for the heater. We'll see how it all goes, but fingers crossed!
Tom
#246 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 17 May 2006 - 11:33 PM
You can still use the mini heater can't you even though the pipes leading to it will probably be a different diameter?
#247 minivanman
minivanman
  • 3,454 posts
Posted 18 May 2006 - 06:45 PM
im positivley convinced you are me a few years down the line. :lol: i reckon i'll put a vauxhall in my van after a few years and stick the 1293 in my car, possibly adding a turbo. ah well, i suppose i need to get the van running with an A series first! one day though....
#248 marc
marc
  • 2,138 posts
Posted 28 May 2006 - 09:36 PM
Have you got any further with this yet tom? Found an engine? I only ask as i want you to get yours running so you can help get mine running when its ready and you can sort any problems before i come across them! Lol.
#249 Purple Tom
Purple Tom
  • 4,921 posts
Posted 29 May 2006 - 08:02 AM
Lol, glad to hear you're waiting for me!
Haven't actually physically got any further, but I've been doing LOTS of thinking of how to do things etc....so although the possible problems are still there, everything is in place in my head! :D
I'll get cracking soon, really need to get my engine out and to the buyer to free up some cash to go spending on C16SE's...:-
#250 Purple Tom
Purple Tom
  • 4,921 posts
Posted 07 June 2006 - 08:25 AM
Right then, things are moving on a bit now...
Lots of stuff from the A-Series department on the car has sold, apart from some of the bigger items which I reckon I'll chuck on eBay soon.
I've just bought a complete C16SE MPi engine/loom/ecu/injection unit, and gearbox, basically everything that came out of the Astra.....I've also bought an F15 gearbox from an Astra TD, as I reckon with the 10's this'll allow me some use of first gear, and will also bring the rpm down to about 3500 in fifth at 70mph. Matt from the 16V Mini Shop has sorted me out with all of this - have a look on the shop and you'll get an idea of what you need to do to do your own conversion! :P
I've decided to go for the Smiths Telemetrix range of gauges, they do some really nice looking stuff, I've got a 0-8000rpm programmable tacho, a 0-140mph programmable electronic speedo with odometer and tripmeter, and I've gone for a voltmeter, electric temperature gauge and fuel gauge.
The fuel gauge needs to be recalibrated, as the Mini sender unit works on 285ohms empty and 20ohms full, Speedy Cables will be doing the work for a tenner, so it will read correctly.
As for the speedo, it uses an electronic pick-up and magnets, much in the same way as a pushbike speedometer does. I was thinking of mounting the pick-up and magnets on the front hub, and using the driveshaft to mount the magnets, but then I thought its possibly prone to damage up at the front, and if wheelspinning would not give an accurate reading. So insteady I'll mount it to the rear backplate, and fix the magnets to the outer edge of the drum, This should allow a correct reading.
Still got lots of other things to sort out, but the basics are there. The frame should be ready in about 3 weeks to a month, engine will be here sooner than that too.
Lets hope I get it all in before the BH2N run! :)
Tom
#251 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 07 June 2006 - 09:03 AM
All I can say is :P
#252 ed4ran
ed4ran
  • 2,849 posts
Posted 07 June 2006 - 11:10 AM
Got any pics or links for the gauges?
Sounds like it wont be long before its in!!!!
#253 GraemeC
GraemeC
  • 7,471 posts
Posted 07 June 2006 - 11:21 AM
http://www.caigauge.com/ should give you a good starting point
#254 marc
marc
  • 2,138 posts
Posted 07 June 2006 - 05:56 PM
Good to hear its coming on tom! I was also thinking of mounting the speedo pick up on the front, quick question on the 16v forums soon made me see sense and to put it on a rear drum.
Get it running so any problems you have i can erase before mines running!! Lol.
#255 Madmax
Madmax
  • 2,638 posts
Posted 09 June 2006 - 11:20 PM
mate ive tried pm ing you about payment on the cooler, youve got a full inbox so when u see this can you be in touch, cheers tom
