Bolt Vs. Studs.
Posted 26 April 2007 - 09:13 PM
A wee question. The engine to gearbox is all studs....normally. But wouldn't bolts and washers do the same job. I mean, can't see the point of buying a load of studs from mini spares when I can get a C**p load of bolts for little money.
Just trying to be cheap is all.
So can it be done or will bad horrible things happen?
Posted 26 April 2007 - 09:28 PM
the studs are there for a reason not just to *yellow human water* you off.
every engine i've taken apart has had 1/4"unf bolts in all holes except the 2 over the diff.
Posted 26 April 2007 - 10:58 PM
Damn you cruel world. damn yoooouuuu!
Posted 27 April 2007 - 12:41 AM
Really? not on my '64 1275. There are only two studs in my car's block. The balance are bolts inserted from the bottom up.
Posted 27 April 2007 - 08:01 AM
I've only taken apart one engine and they were all studs with 1 bolt.
Posted 27 April 2007 - 08:20 AM
Gearboxes are connected with bolts with the exception of the two above the diff housing ( as repeatedly said above )
If you need some... just ask !
However if you're on about the transfer case, then that depends on A series or A+... A+ use bolts, A series use studs
Edited by GuessWorks, 27 April 2007 - 08:21 AM.
Posted 27 April 2007 - 08:37 AM
Posted 27 April 2007 - 08:43 AM
Edited by Dan, 27 April 2007 - 08:44 AM.
Posted 27 April 2007 - 09:23 AM
From block to gearbox, HT bolts are good.
For transfer case (the thing at the side with the drop gears?) use special bolts.
yes?
Posted 27 April 2007 - 12:12 PM
Posted 27 April 2007 - 12:22 PM
One minor correction. The conversion Dan mentioned above is moving up from 1/4 inch to 5/16 inch bolts. 5/8 inch is a wee bit big for just about anything on a Mini.
Thats alright, I don't understand imperial system anyway.
Posted 27 April 2007 - 01:29 PM
Right, well....One minor correction. The conversion Dan mentioned above is moving up from 1/4 inch to 5/16 inch bolts. 5/8 inch is a wee bit big for just about anything on a Mini.
Long time ago in a galaxy far, far away there was this dude, Darth Vader....
Posted 27 April 2007 - 04:57 PM
Oh my god that's funny, I can't believe I put that. What's wrong with 5/8" bolts in the gearcase exactly then?
Yup, or the original studs with locktabs as in the A series if that's what you already have to hand. Shouldered bolts are better though.
Edited by Dan, 27 April 2007 - 04:58 PM.
