Removing the front wings without damaging them...
Posted 23 April 2007 - 01:49 PM
Anyone done this?
MR Benn
Posted 23 April 2007 - 01:54 PM
You'll end up with a load of little holes but it will work.
Posted 23 April 2007 - 01:59 PM
Posted 23 April 2007 - 02:10 PM
I would like them off in one piece ideally, its a very long story....
Mr Benn
Posted 23 April 2007 - 02:16 PM
Posted 23 April 2007 - 02:51 PM
PS, the wing is not attached (or should not be ) to the scuttle..
And dont forget when you come to weld the panels back on, it's likely you're going to have to clean and respray them anyway
Posted 23 April 2007 - 03:26 PM
if the car has original wings you can drill the spotwelds out down the flange under the bonnet and with luck down were it joins the apex panel the hard bit is the ones were the wing joins the front panel and the ones around the scuttle panel.
Posted 23 April 2007 - 04:38 PM
Mr Benn
Posted 23 April 2007 - 05:54 PM
the original wings are spotwelded to the scuttle panel.
No they're not, there should be a skim of seam seal between the scuttle and the wing.....
And yes it will all come off in one section...
Edited by GuessWorks, 23 April 2007 - 05:56 PM.
Posted 23 April 2007 - 06:26 PM
Cheers for the help guys, yet again this site has helped me out
Mr Benn
Posted 23 April 2007 - 06:52 PM
Original factory wings are spot welded allong the scuttle and an absolute b!tch to get at with any sort of tool other than chisling them off
Should be fine if they have been replaced though as most dont weld that area back up
Posted 23 April 2007 - 07:49 PM
maybe all the wings you have done had been done before.
Posted 23 April 2007 - 07:56 PM
I'll find out when I take the front off my 72' which I know is all original metal...
