'91 Mayfair Restoration/upgarde
#121
Posted 04 February 2008 - 07:12 PM
#122
Posted 04 February 2008 - 10:13 PM
#123
Posted 05 February 2008 - 04:35 PM
Fully waxoiled, all underside painted, outside filled & primed & once it's been painted, i've got to take it back to get the rest of the stonechip protection put on.
Basically though, it's almost ready for paint. I'll be painting the indise of the car before it goes in to get painted though.
All other pics are here....
http://public.fotki....sto/page10.html
Comments welcome!
Also, i'll be adding loads more pics as i go along, i need to go and make a list off all the bits i want done before paint.
Edited by M44K TS, 05 February 2008 - 04:36 PM.
#124
Posted 07 February 2008 - 03:12 PM
Also, because i'm going to collect on Saturday, i'll pick up a top tin windscreen. That way, i should have all the glass i need, and most of
the bits for the rebuild.
List of things i might get on Saturday if it's in stock.
Door glass runner
Airbag wheel securing nut
MPI steering cowl
Bumper
Steering colums shear bolt
Think that's all i'll need for now
#125
Posted 09 February 2008 - 02:16 PM
First off, the small things.
Seam trim clips
Window weatherstrip clips
Window weatherstrips
Wiper park switch
Wiper loom repair section (when unplugging the wiring for the wiper from the park switch, they always get damaged due to the terminals rotting)
Wiper motor bracket
Number plate light housing and seal (which are being sent out seperatley as they're not in stock yet)
Numberplate light lens'
Petrol Cap, mine keeps on seizing and i'm sure the key will snap one day
Steering colum shear bolts
2 x floor grommets
mk1 grille
Genuine Rover bumper
Top tint windscreen
Appologies about pics, the setting need adjusted on y phone.... 5mp my arse!
#126
Posted 11 February 2008 - 09:58 PM
hmm, well, after hours of trying to figure out exactly what was up with the headlight switch on the new stalks, i decided to take it apart to see if i could see what terminal went where.
As i opened it up, i noticed exactly what was wrong....
The stalk is broken and not flicking between the different positions on the switch.
This is the tiny bugger that has caused me an evenings worth of headache!!!!
The tiny black plastic selector fork has snapped off inside the switch.
When you select the different positions on the stalk, inside, there is a tiny set of contacts that select the the corresponding terminals by sliding to the left or right. With the selector fork broken off, it was stuck inbetween the different positions on the headlights, which is why i couldn't trace the wiring!!!
So £7.50 and £5 postage later, bought some off ebay from an MGF
Fingers crossed, it should be here by the end of the week, then i can finish off the wiring for them.
Wiring so far... (used the multiplugs from the original harness of the car (black plugs) so theoretically, the new ones should just plug and play.)
Wiper Harness
Indicator Harness
I'll also have to make a 3rd plug in loon aswell for the wiring for the headlight switch as the pre 1996 Mini's has a seperate switch for the headlights to the main beam flasher on the stalks.
So what i'll need to do, is connect the ones back up from the original harness of the headlight flasher, and then make a 2nd loom which will bypass the dash switch ofr the headlights, so it can be connected to the new stalks via the 3rd/new multiplug, which is half of these...
Damn this gets confusing!
#127
Posted 12 February 2008 - 03:34 PM
Now, just need to buy a bootlid for it to fit onto lol
#128
Posted 12 February 2008 - 04:39 PM
#129
Posted 12 February 2008 - 05:24 PM
#130
Posted 15 February 2008 - 04:20 PM
So, got cracking this afternoon sanding it
Once the rusty bits were back to bare metal, used the trusty old kurust
After it was all dry, gave it a quick once over with the detail sander, then some wet and dry to key it up a bit.
Then gave it a coat of white anti-rust primer
Then a couple of coats of gloss black.
Still need to do the other side (which is the side you see when the boot is open) But i'll take pics of that too to see how it comes up.
#131
Posted 15 February 2008 - 04:56 PM
#132
Posted 15 February 2008 - 05:27 PM
One thing i'm unsure of though, the e bullett connectors that are on the headlight loom behind the grille, do you need a special tool to crimp those on?
#133
Posted 15 February 2008 - 06:14 PM
Although Ive never tried using the ordinary crimpers.. they might work?
#134
Posted 15 February 2008 - 06:46 PM
I'll have a look in machine mart/ebay etc.
#135
Posted 15 February 2008 - 06:57 PM
