'91 Mayfair Restoration/upgarde
#556
Posted 10 February 2011 - 10:52 PM
Walnut handles (Need some serious TLC): http://cgi.ebay.co.u...=item4156a15121
Interior set (worth a punt, even if you have to sell the rest on.) : http://cgi.ebay.co.u...=item27b87ecae2
I love my walnut interior bits. Look gawgeous, should look even better with my new door cards and cappings!
#557
Posted 11 February 2011 - 12:42 AM
Posted 11 February 2011 - 10:24 PM
Danny, I bought all my panels from Green & White, http://houghtonlespr...Spares-109-8048
Most mini specialists should stock them though I would have thought.
#559
Posted 12 February 2011 - 03:17 PM
#560
Posted 12 February 2011 - 06:25 PM
Couple of pics of the latest delivery..
Switch panel..
Thermostat housing.
#561
Posted 12 February 2011 - 09:48 PM
#562
Posted 12 February 2011 - 10:29 PM
#563
Posted 17 February 2011 - 12:34 PM
So that leaves a hole in the heater controls where the switch would be...
The solution...
I've just got to find a way of wiring up the resistor now which might mean somehow rewiring the motor. I do love a challenge every now and again.
Huge thanks to Martin/Roofless for the heater fascia, top quality stuff!
#564
Posted 20 February 2011 - 12:05 AM
Bargain at £5, just need to remove the heater from the car and test to see if I can find a way of rigging it up. Then I can have a 3 speed heater
(Google pic)
Basically, it will be wired with, 1 feed to the 3 pos. switch taken from the existing heater supply, then the 3 speeds to the resistor pack, (3 terminals together) then the single terminal goes to the heater motor.
Nice and simple I hope!
#565
Posted 20 February 2011 - 04:18 PM
Yeah make sure you remove the dizzy drive from inside.
Distributor drive thing removed too, Thanks mini_mad69 and Jordie for the heads up, I wouldn;t have noticed it otherwise lol
I wish I had taken my own advice!
I love the more modern features your adding to the car, it looks great.
#566
Posted 20 February 2011 - 04:38 PM
Cheers too mate, just trying to make it a nicer place to be.
#567
Posted 21 February 2011 - 11:43 AM
Shh-ting!
Money well spent IMO
#568
Posted 24 February 2011 - 06:57 PM
New centre air vent section of the centre console arrived this morning, proper walnut veneer, apparently done by an ex Rolls Royce employee, the quality is first rate up close
Cut out originally designed for a cigarette lighter, the back needs enlarged with a router for the heater control to sit flush.
#569
Posted 26 February 2011 - 12:58 PM
Cooper carb air filter and 'snorkel'
Now I know it won't be the best thing for helping the engine breathe, but as I'm trying to quieten the car down with the extra sound proofing that's ready to go in etc, I thought this would be ideal as most of the engine noise at the minute is induction roar. So if this quietens it down a tad, I'll be happy, plus the performance loss should be negligible.
Also, called into Maplin on my way home today and bought a small box to house the blower resistor. I'll be drilling some vent holes in the box just in case it does get hot when in use. Not pretty, but will be behind the dash and won't be seem so I don't really care
I'm also waiting for a new PCB for the back of the clocks to be delivered, some of the tracks on mine got damaged a few years back and I've had to solder sections of wire in to bridge the damage. Also, one of the contacts where the loom plugs in has came off and is currently wedged into the plug. Luckily, they've just been put back into production so should last a while.
I think I might have a trip over to the car and get a few of these small jobs sorted. Probably tomorrow as I don't think I can be bothered to go toady.
#570
Posted 28 February 2011 - 10:55 PM
Swapped the manky old thermostat housing with the new thermostat bilet alloy one
Before
After, (sadly, some of the new bolts that I got in that kit were totally wrong so the horrible old rusty ones have been put back in for now.)
Luckily, the alternator ones fit fine so replaced the old ones with new, still got the bracket to engine block bolts and the adjuster ones to replace. Also touched up the block with some satin black after seeing the pics
Got the Cooper airbox fitted.
New K&N in the airbox
The warm air intake on the underside of the airbox was fouling on the coilpack
So out with the hacksaw
And how it looks fitted
Quickly started the car up and it sounds a little quieter when you rev it, obviously I'll only be able to tell when I drive it
It was getting a little late to do anything else so called it a night, I've got the rest of the engine bolts to swap over next time I'm over, also noticed that after fitting the bonnet shut seal, the bonnet catch needs a little bit of adjustment which will mean drilling out the mounting holes as it needs to be moved further to the right.
Edited by M44K TS, 28 February 2011 - 10:58 PM.
