A small update I know, but couple of bits I've bought over the last few weeks. (yes, more OCD type things)
So, some stainless bumper nuts, the ones I have aren't the right ones hence my front bumper not being 100% secured. Then a set of stainless door hinge mounts, currently, the hinges have small washers behind the nuts, always been a bit wary of that, so decided to buy the correct things. Also, you'll notice that I've bought a set of stickers, mainly to give the engine bay that OE look.
There's a small bit of vibration from the bonnet under deceleration and when on fast idle, so bought some neoprene foam rubber to go along the shut lines of the bonnet to dampen it
I also bought the rotary heater valve control I mentioned, so just got to find a place for that on the dash. As mentioned previously, I'm doing away with the original push/pull heater cable, then opening up the hole and fitting the 12v socket in it's place.
It also came with the cable and heater valve, but unsure if it's for the right size heater hose diameter, might just attach the new cable to the old valve if it's different.
Can't remember if I took a pic of the new jack bag, so here it is
And a jack to go with it, (not that I'd ever use it, it's just going to be for show) The plan is to clean them up and get them looking like new again
Also came with the wheel brace
Then my ebay bargain, dash and lower bulkhead sound deadening pads that are in good condition. My originals went soggy and mouldy years back after I accidentally left the window open for 3 days during heavy rain, (4 inches of water in the foot wells kind of destroyed it) So I'm hoping these will make the car that bit quieter, especially behind the dash where it's needed the most.
Dash sound deadening
Lower bulkhead sound deadening, some bits could do with being cleaned up a bit on it.
Plenty to keep me occupied over Christmas, that's not including a few other small job I want to do on the car either.
