'91 Mayfair Restoration/upgarde
#226
Posted 17 February 2009 - 11:59 PM
Does it power up ok? or is it that you can't get the screen to work or something like that?
#227
Posted 18 February 2009 - 12:03 AM
cheers
#228
Posted 18 February 2009 - 08:30 AM
#229
Posted 03 March 2009 - 10:46 PM
So, here goes....
Bonnet, not properly fitted, just slotted on until the weekend, when i can get a chance to line everything up
Mirrors (over-exposed due to the flash)
Boot
One of the doors
I'll be picking up the W&P arches and the seam strips tomorrow night, then i can get cracking with getting everything fitted back together.
#230
Posted 06 March 2009 - 11:03 PM
Got the last couple of bits from paint on Wednesday night.....
Boot hinges
Seam covers
Arches
I also managed to nab a brand new Rover wing aerial on ebay still in the Rover packaging for about a tenner so need to get that fitted so i can actually listen to the radio!
So, now i have pretty much everything i need, so hopefully over the weekend, i can actually make some progress!
Also, just had word from Mark @ LCS that my speakers have turned up, so should get them next week sometime.
#231
Posted 07 March 2009 - 11:01 PM
First off, i fitted the headlights properly, the headlamp bowls came with a fitting kit which i had 'misplaced' so sorted through the all my parts in the garage and found them. So once the bowls were screwed in right, i got cracking fitting the headlights again.
The new headlights came with new sidellight bulb holder as the original sidelights are attatched to the headlight bulb plug.
So off with the old and on with the new...
New spade connectors on the headlight loom
And new sidelight holders fitted
I also found a black leather handbrake grip that i bought ages ago so fitted that.
Next up was the font indicators.
Then the seam strips. Total pain in the arse as they were a pattern part and didn't fit very well. Luckily, i had a load of spare clips so with help of a hammer, they eventually fitted.
The Boot was next. (Looks a bit bare as there's no numberplate light or badge on)
Sneaky pic of my "off road plates"
Fitted the passenger side door seal and rear 1/4 seal.
New old stock Rover aerial fitted.
Finally, charged the battery a couple of times trying to start the car. Since i connected the tank up, the car wouldn't fire, i tried for ages today cranking the car over, then noticed that a the + wire to the coil had came off (D'oh!)
So with that back on, half a turn of the starter and it fired but was running on 3 cyl, so checked the dizzy cap, one of the HT leads was loose, so a quick fix and it was running again, pretty sweet too considering it hasn't ran for ages. Also, couldn't resist taking it for a quick spin up the street and back, forgot how wierd (in a good way) it is to drive!
Finally, fitted the hinges back onto the doors ready for fitting back on the car.
After all that, went over the car with some quick detailer and then some wax, paintwork looks even better now!
Next couple of things that i'll be fitting will be the bumpers, grille and the doors, then hopefully the glass, although i can see that being a pain!
#232
Posted 09 March 2009 - 05:15 PM
Inbetween the vents in the center console.
I'm going over tonight to fit the bumpers, grille and build the doors back up hopefuly too
#233
Posted 09 March 2009 - 11:29 PM
The bumpers didn't come with any nuts so i'll have to source some for the back bumper, front one, i had some nuts that fitted onto the studs on the bumper, but because the front panel is a pattern part and not a heritage panel, the holes are slightly out of allignment so i'll have to widen them a bit.
Anyway....
(Excuse the pics, i forgot my camera so had to use the phone)
Grille and surround on
What it shall look like with the plate crudely taped to the mounts (show use only officer!)
And the rear 1/4 cappings on. (Still need to fit the rear arch trim piece but i need to buy some more contact adhesive)
Didn't have time to do the doors, but i'll try and get them done over the next few days.
Also, i'm in a dilema about what badges to use. I was thinking the late model winged badges....
But they might look out of place with the mk1 front end, so was thinking something like this for the front to give it more of a retro look....
Or this
For the back, i think this would look alright under the boot handle...
Opinions anyone?
#234
Posted 09 March 2009 - 11:36 PM
#235
Posted 09 March 2009 - 11:39 PM
#236
Posted 10 March 2009 - 09:45 AM
I'd go for that
And yeah id go for the Mini in chrome on the boot
#237
Posted 10 March 2009 - 03:47 PM
#238
Posted 10 March 2009 - 04:06 PM
#239
Posted 11 March 2009 - 11:48 PM
Whilst i was over the garage getting the handles, i happened to stumble upon the old numberplate light housing, which as it happens isn't in bad condition, but more importantly, it had the 3 fixing bolts attatched to it which i thought i had lost, and finding replacements was a total ball ache.
Only problem was, the new light lenses didn't come with any screws/bolts (or atleast i don't think they did!) So thought i couldn't fit them as the old ones in the old housing had rusted so weren't useable, but tried some small self tappers and they fit fine, so took the oppourtunity to fit the numberplate light. I think that's the last job to do on the bootlid apart from the boot board on the inside of the lid, but that can wait.
So, one step closer to completion.
Lights connected to check they're working.
Fitted
Job done!
#240
Posted 12 March 2009 - 09:44 AM
Here is a suggestion for the back, it's a picture of my own Mini:
Keep up the good work!
