thnx Aaron.....was thinking along these lines with mine but i a little worried that its going to be a little flimsey..i have the steel to make a completey new 1 from scratch...owell i'll see....thnx for that and good luck with your build
here's my build if ur interested....my build
Aarons 16v Mini On Its Way !
Tangoâ„¢
, Apr 19 2007 08:17 PM
65 replies to this topic
#61
Posted 09 December 2008 - 03:35 PM
#62
Posted 09 December 2008 - 05:48 PM
Ah that’s you!
You already know xevalver then lol... he is exactly where I got all my ideas from. Yours is a great build by the way and I have been following your build for a while. Your build seems to be developing a lot faster than mine
On your build do you plan on going clubman front or round nose with extra length?
I also plan on putting an extra mount at the back like you, but I am a little worried that it might crack the block where the water pump is.
I am hoping that the pedal box won’t be flimsy when I finished but if it is ill just modify to suit.
Aaron
Aaron
Edited by Bad_Dobby, 09 December 2008 - 05:50 PM.
#63
Posted 09 December 2008 - 06:40 PM
xevalver is where i got most of my insperation from for the frame
i thought that my build was a little slow...i'm trying to keep the round front hopefully with not too much exstention
as for the rear top mount IT IS A MUST there's been few of the early 16vminishop frames with snapped bottom mounts.think bassadicts if i remember also some homebrews like xevalver his also snapped his rear cross bar..thats why i put the fourth mount on.....and rienforced the rear crossbar(just welded some 3mm plates over the joints
if u do the fourth mount try and get it so the mount is on compression if using the landrover mount as this is how these mounts are supposed to be
as for u saying u was a little worried about it cracking the block at the water pump u shouldn't have any problems as this is where the later allspeed frames/16vminishop frames are have a look here
16vminishop XE FRAME
#64
Posted 09 December 2008 - 07:21 PM
Thanks mark
Just looked at the pedal box on the website and at £125 I think I will be defo making my pedals work! Also just ordered a brake reservoir from the same person you got yours from.
http://myworld.ebay....motor_sport100/
Aaron.
Aaron.
Edited by Bad_Dobby, 09 December 2008 - 07:22 PM.
#65
Posted 09 December 2008 - 07:27 PM
pedal box is abit on the exspensive side...thats why i might make my own and base it on measurements i have from the original mini pedalbox.
#66
Posted 22 March 2009 - 05:56 PM
PROJECT ON HOLD!
After a couple of years neglect my mini cooper needs work to pass the MOT. This means that the clubman has to swap garages with my cooper. I have also just bought a house while the house prices are cheap! Will inform and update when I get the clubman back home and have some cash to spend on it.
Regards
Aaron
Regards
Aaron
