Well it’s been a while since I last posted my last pictures and nothing has really progressed on the build as much as I would have liked by now. I managed to grab a small alternator off eBay, and I received my DIGIDASH from ETB (
http://www.etbinstruments.com/).
I changed the clutch on the car but to be honest it was a cheap and looked nothing as good as the one that was already in, so I will have to see if the clutch lasts. Ordered my SPA mirrors (with free delivery too!) and arrived some months ago now. Very small and just what I wanted.
Whilst at mini in the park I bought some new indicators as the original ones have broke around the steering column.
Oh and here is what I want my mini to look like with a few slight changes in style.
So with the front subframe finished I put the engine back in and started to make the new gearlever mounting , needs a slight adjustment but I think it turned out alright.
I have some slight issued with the clearances in cretin areas such as the alternator which even though it is very small, there isn’t much room for adjusting it. It’s also very close to the subframe bolts which I put in while the engine was out and forgot about the alternator belt. Hopefully I can move the engine slightly to the right to miss the bolts.
I have so far been able to retain the exhaust which I must thank the person who designed the clubman for leaving just enough room for the exhaust manifold to pass.
And finally I cut my dash so it now fits over the steering column and round the subframe. There are some areas around the roll cage which needs to be tided up.
Until next time
Regards
Aaron
