Steering Column Drop Bracket
Posted 16 April 2007 - 05:58 PM
They say to loosen the 4 nuts on the floor, but I only have two going to the U-bolt holding the steering rack. I'm guessing I need to loosen just those.
The main problem is the bolt holding the steering column to the existing bracket: it's smooth on both sides. Like a carriage bolt and nut. No flat surfaces to put a socket on. I hope it's something really simple that I've missed.
Anyone else encounter this?
Thanks,
JT
Posted 16 April 2007 - 06:36 PM
how to fit drop bracket
Jordan
Posted 16 April 2007 - 06:39 PM
Either file a flat on one side (there should be one side with visable thread sticking out the end. Do the opposite end) then take it out.
Posted 16 April 2007 - 07:27 PM
As stated above there are four nuts on the toe board that hold the steering rack to the body with U bolts, two nuts on the passenger side and two on the drivers side. These need to be slackened off before you move the column, You also need to be sure that when you do move the column that the rack also moves with it. There should be no pressure on the joint of the column to the rack. If there is its a matter of time before the splines give up on the rack and the end result could be nasty - this guy was lucky
Posted 17 April 2007 - 05:23 PM
Thanks again,
JT
One side is a shear bolt the other is a shear nut. You need to file two flats on the shear nut, parallel to each other then you can use an adjustable spaner to remove the nut. If you try to do this on the shear bolt it will not move as its posatively located in the column bracket. You can replace this with a standard high tensile nut and bolt.
