Steering wheel off the center after accident but doesn't pull left or right
Posted 16 April 2007 - 09:46 AM
My first post in the forum and hopefully someone can assist with my problem. Long story short, had an accident to the left front, nothing big the hammer and some paint won't fix, the other car had just a scratch on the bumper but mine got more due to rust under the light. After the accident the brake pads on the left brake very unevenly making the car to vibrate heavily. On the road doing 60 mph there are no problems only when breaking. The car doesn't pull to any directions and is straight. But the steering wheel isn't exactly center any more, just a bit off.
Maybe the left wheel got some damage with that the break disc and pads?? What do you reckon? Should I go and get the wheels aligned??
Appreciate for all help,
Rgo
Posted 16 April 2007 - 10:16 AM
Strongly suggest you get it up on some ramps and get it check out before doing any serious driving...
If one of the arms is broken the last thing you need is the suspension letting go @ 60mph...
Posted 16 April 2007 - 03:41 PM
I also threw the tracking off and had the steering wheel off to one side a small amount. In my case the impact was strong enough to twist the front subframe, so check to make sure yours is still true and as above, check everything else under there.
SS
Posted 16 April 2007 - 05:33 PM
Posted 17 April 2007 - 10:52 AM
All other parts seemed to be ok and not broken bent or twisted. Hopefully the new bearing will make the breaking smooth and easy.
Of course will let the wheels aligned aswell.
Posted 17 April 2007 - 11:33 AM
I would do some further investigation personally.
Posted 18 April 2007 - 08:11 AM
Posted 09 May 2007 - 09:15 AM
Posted 09 May 2007 - 10:16 AM
Posted 09 May 2007 - 10:40 AM
I suspect they mean that the wheel itself is now not central on the column...not that the column itself is off centre?!The steering wheel is supposed to be slightly off centre. This is just the way they were made....
Make sure they are able to do Minis...some centres can't as they don't have the kit for older style cars....especially if you have 10 inch wheels!How much did it cost for your tracking, and where did you go if you dont mind me asking?
Posted 09 May 2007 - 01:16 PM
