MINI BUSA II
132 replies to this topic
#106 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 07 April 2008 - 04:05 PM
I took the car last week to oulton park for the first round of the racing to have it checked over by the scruitineers which said it would be fine for racing!! :(
It got raped of a few parts by the Zcars team but all in a good cause and resulted in a 3rd place overall in the second race.
The replacement parts arrived last week for me to rebuild the front hub and get it back on its wheels. Finally renewed the insurance with sureterm with the help of the miniforum discount!! :thumbsup:
Took it for its first run out since last summer which was about 5 mile to check everything was ok and no major issues, once it was warmed up i gave it a bit of stick through the gears and all felt good right up until the clutch decided to start slipping but i managed to creep it back home under light throttle. ^_^
After a few phone calls and words of advice i started to do some elimination to check the clutch cylinder was not holding it off and that the pushrod which runs through the engine was not bent in anyway and binding down the centre of the mainshaft and all was ok.
Time to strip the clutch cover off.
Everything was really clean inside.
stripped of the pressure plate cover to check for worn friction plates and damaged drive rings but as you can see everthing is in order and the plates show little sign of wear and are well within tolerance before they require replacement.
The only thing i could find wrong is that the wet clutch and was completely dryof oil for some reason?? which is strange as its pressure fed from the main oil gallery and has a spray into the clutch basket. I will crank it over later to check we have oil coming out of the basket area.
(the pictures are as they were removed and i hav'nt wiped or cleaned anything yet)
I have decided to change the oil from Castrol GPS bike oil to Silkolene 10-50 Pro4 Plus.
Im leaving the plates soak overnight in the dogs bowl in the oil befor refitting tomorrow when my goodies arrive from Powertec!!
more to follow........................
#107 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 08 April 2008 - 05:50 PM
Springs and clutch pawls turned up from powertec today so im now able to get things back together
The Pawls help to smooth out the clutch judder on the hayabusa engine acording to Powertec who fit them on all their engines they build.
They fit in here to get rid of the Ramp action on clutch engagement
Just need to reassemble the clutch basket with the new springs tomorrow, off to work again now. :)
Edited by markrally, 08 April 2008 - 06:50 PM.
#108 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 16 April 2008 - 03:51 PM
Not had time to usdate on the clutch situation but all is well again now and it certainly feels a lot better and more like a car clutch which is easy to set off with now and very progressive with no jerkyness.
So on with the next Mod:
I allready have the cold air feed pipes installed but i have been waiting for the Airbox from Zcars
So out with the old
And in with the new
Short Std Hayabusa trumpets fitted (CHEERS KOSS ;D )
K+N elemnt fitted
Air intake temperature sensor fitted behind the filter so should the retaining nut come loose, It cannot go into the engine if the loctite fails
Its a tight squeeze but it just goes in nicely
I just got the air intake pipes to fit tomorrow and off to the rollers friday to check the Fuelling is ok with the new intake and exhaust system.
#109 Jammy
Jammy
  • 25,397 posts
Posted 17 April 2008 - 08:24 AM
That airbox doesn't allow much room for engine movement! lol
#110 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 18 April 2008 - 04:19 PM
where did you get the green foam air filter from? i need something like that for my throttle bodies on the BMW head conversion
#111 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 18 April 2008 - 04:56 PM
Its a pipercross air filter.
Heres the full power run from today
cheers
#112 supermotolee
supermotolee
  • 1,120 posts
Posted 18 April 2008 - 09:02 PM
why did he bring the revs up like that?
and what power did it make?
#113 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 19 April 2008 - 01:58 PM
The Rollers are controlled via a computer and are used in manual for setting up a specific rev range and then an automatic run is done by starting a t a specific RPM say 3000 and keeping it at full throttle and then the rollers then control the load and let the revs rise accordingly up to the maximum rpm which in this case was 10500. Hence the step-up rise in revs.
cheers
#114 MUTLEY
MUTLEY
    Just On Tickover
  • 5 posts
  • Local Club: central
Posted 19 April 2008 - 06:22 PM
so what power did it give.
I thought you were racing this car, isnt the second round tomorrow
#115 supermotolee
supermotolee
  • 1,120 posts
Posted 20 April 2008 - 02:47 PM
wow thats cool never seen a dyno do that before, impressive.
#116 Ro8bieg
Ro8bieg
  • 1,581 posts
  • Local Club: Fylde Mini Club
Posted 20 April 2008 - 09:25 PM
Can you buy them intakes on ur rear arches from anywhere?
I rather like them ;) Fantastic mini by the way!!!!!
Robbie
#117 hotdog
hotdog
  • 82 posts
  • Local Club: stringfellows !
Posted 21 April 2008 - 07:43 AM
mark just had a quick look at your project pages,is your last name HAYNES!!!!!!!!! if you take less photos you would save 50% build time lol. keep it up its great info
regards rob
#118 ninham
ninham
  • 296 posts
  • Local Club: Anglian Mini Club
Posted 23 April 2008 - 03:16 PM
Love the project >_<
Do you know were the Dash came from.
James
#119 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 25 April 2008 - 09:02 PM
I have been playing with some video editing soft ware today, managed to knock this up
clicky
#120 brandon7
brandon7
  • 274 posts
Posted 26 April 2008 - 10:33 AM
Lovin the montage music there! really gettin me psyched up for my build!
WWoooooo :-
