It has now become apparent since the race series has started that the rear brakes need to be improved some what to balance up the braking effort when the larger front brakes are fitted as it tends to lock the fronts before the rears as the disc size / pad area is a lot bigger.
Now on the race cars thay are fitting Wilwood 4 pots all round but that does not give a road legal handbrake unless you fit a seperate handbrake caliper aswell.
In the interests of keeping a parking brake for now i wanted to improve the rear braking efficiency and not break the bank at the same time!!.
I currently have some Tarox 6 pot calipers and 260mm discs on the front so the rear needs a bit of balancing up now.
I have researched the brake disc catalogue a bit and come up with a disc which will be a very tight fit but should jut go under a 13" wheel. Well the measurements say they do!!!
The original disc fitted to my car measured 218mm in diameter and the new one measures 251mm
Another problem i also noticed that the pads i removed were tapered in wear on both sides ??
As you can see from the disc pics, it has been wearing unevenly and only using half the disc area effectivlely.
I did attempt to straighten the calipr mounts up but it wasnt a good soloution.
Here is the original setup on the trailing arms
The brackets have a dogleg in them to be able to get the caliper in the right posistion and be able to weld them onto the arm instead of the hub/bearing housing and to be honest are a bit flimsy as they bend easy.
I have made up a thicker set of brackets from 6mm plate
I have also made some spacers to offset the caliper/bracket and some longer High tensile bolts
I had to machine the flanges a little as they were a little tight going over the flange but different brake disc manufacturers may vary.
New disc mounted on the hub
Heres the first trial fit of the bracket and pad carrier. Not bad measuring and cutting out as the pad is flush with the disc edge.
Thats all for now, i just wanted to trial fit everything before i cut the old caliper brackets off the hub.
Will update later in the week when i get the brackets welded on.
