MINI BUSA II
132 replies to this topic
#16 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 11 June 2007 - 06:06 PM
Carpets, OMG!!!! :)
Dont you start lightweight!!!
I had it weighed at the local weighbridge last weekend and it came in at 620kgs
So going by the last one i built which came in at 580Kgs this one has full glazing, window winders, Side impact protection bars still fitted inside the doors and a full bulkhead so there must be at least 40-50Kgs in that lot but it means a bit of expense to remove it at the moment.
At least i know where all the weight is.
The Red Zcars racer weighed in at 542Kgs if i remeber rightly after the last race at Oulton park.
#17 R1minimagic
R1minimagic
  • 4,660 posts
Posted 11 June 2007 - 06:26 PM
Soooooo heavy!!! :)
#18 oli79
oli79
  • 144 posts
Posted 11 June 2007 - 08:52 PM
Carpets, OMG!!!! :)
May be carrying a little weight but it still looking great mark bet you cant wait to race it now
#19 GraemeC
GraemeC
  • 7,420 posts
Posted 13 June 2007 - 10:13 AM
Is the harness bar braced to the tunnel, as per the SD one, or is it simply a straight bar between the cage legs with the eyelets welded in?
#20 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 13 June 2007 - 10:49 AM
Hi Mark, why was the harness bar a pain to fit ? Does it have to be slotted in from the bottom then moved upwards ? or will it go in diagonal ?
I have just got some cds to make mine.
#21 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 13 June 2007 - 11:35 AM
The harness bar just goes between the main hoop legs.
Koss, As the main hoop is tapered from the bottom-top, and the clamps are shaped to wrap around the hoop, the bar is made to exact length to sit in the required posistion, so i had to remove the bulkhead side panels which were all bonded in, (Easy fit really on a new build) and then slot the bar in diagonally which only just clears the cam cover then move it up to the height.
Edited by markrally73, 13 June 2007 - 11:38 AM.
#22 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 17 June 2007 - 07:49 PM
Looks smint. think you need to get some videos of it on youtube and link them here :w00t:
#23 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 17 June 2007 - 08:31 PM
Dont worry, Im making an in car camera mount for it as we speak!! :w00t:
#24 koss
koss
  • 1,399 posts
Posted 17 June 2007 - 08:45 PM
mark cheers for reply, I think I will go for some machined ends that hinge and bolt up with a couple of allen bolts.
I am not taking the bulkhead out. A bit like the fittings on bus safety rails but in steel.
#25 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 17 June 2007 - 08:46 PM
cool..... :w00t:
#26 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 23 June 2007 - 06:26 PM
Heres the in car camera mount finally fitted in the car
Thanks To Gr4h4m for donating the screw adaptor to fit my camera.
I will go a do a few test runs soon to see if it suffers from too much vibration???
Yesterday i also did a wedding convoy for the chairman of our local mini club WWW.MINIADDICTS.CO.UK Running behind the stretched mini Limousine they had hired from Dereks mini centre and a few other club members cars aswell.
It was a shame the weather was a little wet but it didnt spoil the day.
#27 supermotolee
supermotolee
  • 1,120 posts
Posted 24 June 2007 - 05:13 PM
how do you find it driving at normal sensible speeds ?
#28 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 24 June 2007 - 05:24 PM
It is quite dosile to drive to be honest (Even the wife will drive it) but it will bite you if you press too hard in the wet!!
#29 supermotolee
supermotolee
  • 1,120 posts
Posted 27 June 2007 - 04:07 PM
good show!
i've just finished fitting the R1 engine in the front of mine with darrens promotive kit the tracking and suspension are well out but its quite lairy to drive at the moment once i get used to how sensitive the throttle is i'm sure it'l be ok...
cheers lee
#30 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 28 June 2007 - 04:00 PM
It sounds like you need to alter the pedal ratio for your throttle as the bike only neds a small omount of cable travel whereas the car pedal moves quite a bit so Zcars do a conversion to get around this but you could make this up your self.
You can just see it here in my old car build, a simple lever which pulls the bike cable at the bottom.
Let me know if you want the maeasurements as you maybe able to fit this in yours or cut your throttle pedal and move the pivot/hinge higher up towards the cabe fitting???
