i want to set up my Kad pedal box as i have my sva test soon
i got instructions with it but after reading through other ades posts it took some adjusting, basically im looking for a ball park to work from
cheers
Posted 03 April 2007 - 08:45 PM
Posted 04 April 2007 - 12:46 PM
hi,
i want to set up my Kad pedal box as i have my sva test soon![]()
cheers
Posted 11 April 2008 - 06:53 PM
hi mark just joined forum and after reading your post was wondering if you could help with how kad pedal box plumbs?hi,
cheers
What do you want to know ady??
I setup mine pretty easy really and it gave no problem.
You can call me if you wish?
Posted 11 April 2008 - 08:33 PM
cheers
Posted 12 April 2008 - 05:50 PM
hi Mark looking at car from front you have two master cylinders i take it one does front one does rear is it just a question of running to a tpiece to split to left and right calipers and the same for the rear?Had a look at your photos and just cant make it out,looks good though.hi mark just joined forum and after reading your post was wondering if you could help with how kad pedal box plumbs?hi,
cheers
What do you need to know??
Posted 12 April 2008 - 08:16 PM
Posted 13 April 2008 - 12:25 PM
Posted 13 April 2008 - 09:27 PM
Posted 14 April 2008 - 07:26 PM
Posted 14 April 2008 - 08:32 PM
Posted 29 May 2008 - 03:42 PM
Posted 29 May 2008 - 04:33 PM
I know this is an older thread but is it OK to use a clutch cylinder as a brake, I thought the brake ones had a return in them? Thanks
Posted 29 May 2008 - 05:00 PM
Posted 15 July 2008 - 11:45 PM
