yes i have searched both here and TM
so i understand the T3 were metros original turbo. i also understand people say its not as good as a T2 due to amount of lag. by all means correct me if i miss anything of am wrong.
1. im guessing theres a reason as to why they used T3 in the beginning as opposed to a T2?
2. what actually causes 'lag'? not sure how a turbo unit works.....
3. is there a way to cure/beat/cut down on lag?
4. boost (or psi). its ok saying a T2 is good for 180 BHP - does that mean a T3 isnt?
5. if a T2 kicks in at lower revs than a T3, is this a big range difference i.e. T2 at 2000RPM and T3 5000RPM? (figures used hyperthetically)
6. would choice of cam alter performance accordingly with use of T2/T3 (as in are some cams better suited for each turbo)
i am aware some of these may have been answered already but thought it might be nice to have 1 post covering the basics rather than lots of posts!
cheers
mic
The reason BL used the T3 was because they didn't have the range of Turbos available, that we do today. The T2 didn't exist for a start.
The Turbo is basically an exhaust driven compressor, the larger the exhaust turbine the more gases it takes to get it spinning {more lag}, but ultimatley being able to flow more {higher power}. A smaller turbine obviously taking less inertia {less lag}, but not being able to flow as much.{lower power} So it's a case of trying to match the Turbo to the engine.
The Renault 5 spec T2 is spot on really IMO, my motor made 184hp on one of these. Though after 6,000rpm the power falls flat on it's face with this Turbo, and boost becomes inefficient above 16/17psi, even with the huge alloy intercooler i run.
It would probably have made more on a bigger Turbo, but i like the drivability of the smaller unit.
Running a well matched Turbo, optimsed ignition timing and as high a compression as safely possible will all help reduce lag.
I've run a stock T3 and it came on boost properly around 3,500, the T2 comes in around 2,500.
The best Turbo cams have little overlap, but a big exhaust duration. The Avonbar P2 being a popular choice. The normally aspirated MG metro cam is also good.
things such as fitting an intercooler will help with turbo spooling up time.
To be fair a well set up tuned up turbo mini running a t3 will be spot on as you can gain more power out of it.
But ive also heard the other side of things once you driven a t2 then you will want to change yours, however i cannot comment on this only pass on word of mouth as i only own a t3 mini
Fitting an intercooler will, if anything, increase lag as the compressor has the intercooler and associated pipes to fill before the compressed charge reaches the inlet.
You may be able to gain more peak power running the T3, but on the road while you're waiting for the T3 to come on boost a T2 would be on boost more often and be much more driveable.
I know of lot's of people , myself included, that have moved from a T3 to a T2. I do't know anybody that's gone the other way. I think that says it all.
