Brake Fluid Test Switch
Posted 21 March 2007 - 03:03 PM
I'm building a Funnbuggy Freestyle with the donor car being a 1988 Mini which had circumed to the rust fairies. Anyway the problem is I took her for the SVA yesterday & one of the things she failed on was the symbol on the switch that tests the brake fluid circuit. It's a red flick switch with a symbol of a foot & a brake pedal on, this is not acceptable for SVA & it's got to be the round symbol with two curves at each side similiar to (O) does anyone know if the later Mini's had these fitted?
Alan...
Posted 21 March 2007 - 03:11 PM
But i will stand corrected if any one knows any more because the 1995 spite is the newest mini i have been in!!!
Posted 21 March 2007 - 03:31 PM
I thought the (O) symbol was for the handbrake?
Posted 21 March 2007 - 03:39 PM
Posted 21 March 2007 - 03:56 PM
On the other hand, remove it and they can't complain ! lol
Posted 21 March 2007 - 05:48 PM
And that symbol just means brake system warning. It can mean low fluid or handbrake applied (on most modern cars it means both) but I think the pad wear warning is a bit different.
Edited by Dan, 21 March 2007 - 05:51 PM.
Posted 21 March 2007 - 06:10 PM
Once again TMF to the rescue.
Alan..
Posted 21 March 2007 - 06:14 PM
Thanks Dan, I had since found it on Mini Spares but at twice the price & it wouldn't tell me how much postage till I registered (Don't like that).
Pm Simon@Minispares on here. He'll tell you and you get 5% off for being resisted here on TMF
Posted 21 March 2007 - 06:55 PM
SS
Posted 21 March 2007 - 07:40 PM
Uhmmm, why dont you just go to a scrap yard and cut the correct symbol out of the dash of another car and use it to replace the little plastic light window in the switch? only takes a few mins to dissasemble the switch and swap it over.
SS
From the link that Dan gave it works out at about £12 delivered, it's not worth hassle of trying to find a new mini in the local yards.
Thanks for all the replies.
Alan...
Posted 22 March 2007 - 02:11 AM
SS
Alan...
New mini?? ANY new-ish (under 15 - 20 years?) car should have the same symbol, they are quite common....ah well, whatever works that's the main thing.
Actually, I have one on a dead dash cluster...Think it's way too big to use for the same switch however, though would be OK if you wanted to move the warning lamp to the dash. here's a pic (I belive the correct one is to the right of the coin):
(5p coin is for size reference)
I can cut it out if you want it (for free), I'll just stick it in an envelope and post it, just let me know.
SS
Posted 22 March 2007 - 09:53 PM
Had a few fail in early days due to excessive body contortion to see tell tale lights.
Posted 22 March 2007 - 10:03 PM
Yes I got the ok with the dash. The switches were from a 94 mini. But only just passed due to them protruding no more than 9.5mm and being less than 2.5mm radius on the edges.
I thought I had thought of this & put the switches in the 127mm exempt area, they unfortunately were still in the passenger area, but they only knocked the back of the pod.
Alan...
Posted 22 March 2007 - 10:12 PM
Sorry alan a bit confused, I know the 127 but was it viewing or radius.Yes I got the ok with the dash. The switches were from a 94 mini. But only just passed due to them protruding no more than 9.5mm and being less than 2.5mm radius on the edges.
Alan...
Posted 22 March 2007 - 11:18 PM
Sorry, should always read posts before hitting submit, in case you write something completelySorry alan a bit confused, I know the 127 but was it viewing or radius.Yes I got the ok with the dash. The switches were from a 94 mini. But only just passed due to them protruding no more than 9.5mm and being less than 2.5mm radius on the edges.
Alan...
Alan...
