brake squeel
Posted 11 March 2007 - 07:45 AM
Posted 11 March 2007 - 08:16 AM
It could be the make/material of the brake pad.
Posted 11 March 2007 - 09:03 AM
Posted 11 March 2007 - 09:34 AM
Its why i was asking what make/grade pads he has.
Posted 11 March 2007 - 10:27 PM
Posted 26 March 2007 - 06:25 PM
Put copper grease on the back of the pads, the surface that is pushed by the piston. Don't put so much grease that it falls/squidges out onto the brake disk! just get a brush and apply it liberally. Always works. Don't ask me how!i am using stock ferodo pads. the discs are stock too.
Edited by panelbeaterpeter, 26 March 2007 - 06:26 PM.
Posted 26 March 2007 - 08:44 PM
i was told to chamfer the pads with a file to take the edge off of them. i dont normally have this problem tho. i always liberally apply copper ease to the pads anyway. i may try a different pads when money allows. its not a big issue tho as they stop on a dime still.Put copper grease on the back of the pads, the surface that is pushed by the piston. Don't put so much grease that it falls/squidges out onto the brake disk! just get a brush and apply it liberally. Always works. Don't ask me how!i am using stock ferodo pads. the discs are stock too.
Posted 28 March 2007 - 09:38 PM
Also might be worth getting the discs groved to help with venting. Pad material gives off gas when they get hot. This is what causes brake fade. Cyclone solutions in Wickford can grove discs at a cost of £15 per discs. Get yourself a cheap set of discs and have them groved, cheaper than buying them from the shops at a cost of approx £90.
Or simply turn the radio up louder thats what I do.
Posted 31 March 2007 - 12:37 PM
Due to the material used to make brake pads, they tend to be alot harder than when they used abestos. This tends to cause groves in the discs surface which brake dust gets trapped in. Have you checked the surface of the discs ?????
i see where your going but thats not the best advice, imho
the whole point of grooved discs is that it gives the brake dust and gases somewhere to go, thus improving braking performance.
i wouldnt recommend getting your discs machined, especially when there not intended to be grooved. i would hazard a guess and say they would be highly prone to warping and cracking
just spend the extra dosh if you want grooved, then you got a guarantee.
this is from http://www.ebcbrakes.com/QandA.html
SHIMS - WHEN DO I NEED THEM?
Many semi metallic pads (those containing steel fibre) come fitted from the factory or aftermarket suppliers with rubberised metal shims on the back to prevent rattling and squealing. This is because of the type of material they use. At EBC we very rarely use shims because in 99 cases out of 100 we do not get noise, due to the non metallic nature of our pads. In certain cases however and in certain types of use, especially “under-use” shims may be necessary to quieten a pad. These can be obtained from EBC free of charge by simply calling 818 362 5467 and stating the type of vehicle. These will be sent out to you and again reminding you that the installation costs are for the customers account, we do not warranty this fitment charge or consider it part of our guarantee.
might help if you've tried everything else...
Posted 23 April 2007 - 04:55 PM
Posted 26 April 2008 - 08:13 PM
My understanding of why brakes squeel is that its the pad vibrating against the caliper/carrier at a certain frequency causing the noise. That is why the copper grease can help as it "dampens" the tiny vibrations, and it's the same principle for the shims. Alot of cars come with a shim of some kind from new to prevent squeel (Nissan Primera P12 rears for example!)
Posted 22 May 2008 - 05:53 PM
Posted 23 May 2008 - 12:46 PM
Posted 23 May 2008 - 08:32 PM
Posted 23 May 2008 - 09:14 PM
