shocks and hi-lows
Posted 06 March 2007 - 01:58 PM
im planning on buying some GAZ shocks some point soon. which ones should i go for lowered or standard adjustables?
i know with the lowered ones, they stop the unit coming apart when being lifted up, and stop from bottoming out - but is there any other advantages?
Do i need any modifications to fit lowered shocks?
which are peoples preference? and why?
Another thing - is there any different between minisports adjusta rides kit and minispares Hi-Low kit
again, what are peoples preferneces? and why?
thanks
JoeB
Posted 06 March 2007 - 02:05 PM
Posted 06 March 2007 - 03:29 PM
Yes there is a big difference between the suspension adjusting units. Mini Spares Hi-Lo kit is the original and best unit and is patented. The spring seat on this unit has a specific shape to alter the way the spring behaves and make it more progressive, important when the suspension is lowered as you are reducing the total suspension travel available and so need the spring to be more responsive. All the other makes, including the Mini Sport version are just cheap copies of this original. The Hi-Lo was originally designed and patented by Ripspeed and produced by Mini Spares under licence, this was before Ripspeed became nothing more than a different desk with the same clueless youth behind it at Halfords of course.
Posted 06 March 2007 - 03:41 PM
Quality
Posted 06 March 2007 - 03:48 PM
I set the ride height to standard on my Mini, or perhaps slightly raised to compensate for the fact we were using it for family camping holidays and having to put up with sleeping policemen etc.
Posted 06 March 2007 - 07:58 PM
as i plan to lower down the back a bit - but only a lil bit
Posted 06 March 2007 - 09:16 PM
Posted 06 March 2007 - 09:29 PM
so if i lower the suspension using the hi-lows i will need lowered shocks?
Yes you might do, depending on how far you lower it. I would say you should fit the Hi-Los first and set the height where you want it (bearing in mind that it will take a few days to settle) using the standard shocks before you decide which new ones to buy. You will know if they are bottoming out regularly in normal driving or not and this will tell you which you need. If they do start bottoming out badly you need to change them ASAP. There are no definites here, some setups need lowered shocks and some don't. It depends on many things.
by the way you know the back is meant to be higher than the front don't you? Lots of people try to adjust out what they see as an error in the ride height but don't realise that it is part of the car's design.
Posted 06 March 2007 - 09:31 PM
Posted 06 March 2007 - 09:56 PM
............................................................................abou
bikes
Posted 07 March 2007 - 08:04 AM
why does it sit higher at the back then? mines looks stupid wit it only running on 10s - nice n close to the arch at the front - about 2 - 2.5" gap between tyre and arch at the back???
Posted 07 March 2007 - 08:14 AM
When in normal state the mini has a driver.... when fully loaded the mini has 4 occupants and a boot full of shopping... this affects the weight of the car and also the suspension.... hence why the back is higher, to compensate...
or...
The rear is higher to affect corner weights, with it being higher, it moves a greater proportion of the cars weight to the front, over the driving wheels.. Change the suspension height affects these corner weights, and could impact the handling of the vehicle... You should re-adjust the corner weights when using hilos, not that anyone does.
Posted 07 March 2007 - 12:15 PM
as i remeber there being something about that you couldnt run them with negative camber??
Posted 07 March 2007 - 12:28 PM
if i bought lowered shocks will they fit if im running 1.5 negative camber ?
It's possible your rear wheels might rub the shocks if you add too much negative camber...this happened to me so I used some thin spacer shims. That said, it is as much (or more) due to the increased diameter of uprated shocks as the increased neg. camber.
As far as I know the front should be OK, so long as you don't have ridiculous amounts of camber. If you mean you will be using the fixed '1.5deg camber arms' then your camber will be likely 0.5-1degree (negative), which will be fine.
As for rear ride height, I usually lower the back so that it is slightly higher than the front...some mini's look very jacked up at the back, which is probably not neccessary (IMO) especially if you don't use the car for heavy loads or have many passengers.
