2 up 2 down lamp brackets
16 replies to this topic
#1 mini25
mini25
  • 359 posts
Posted 19 February 2007 - 03:08 PM
has any one got any pics of minis with these fitted?
are they 2 brackets or are they bars like the 2 and 3 lamp ones?
also any one know were i can get sum? i couldnt find them on minispares website and a quick search on here didnt find anything
#2 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 19 February 2007 - 07:06 PM
do you mean these ones?....
well if you do, you can get them from a few places but it think mine were from a show and i cant remember the name of the company i got them from (but they are still around).
they are basically two spotlights mounted as normal with a bar running between the clamps on the lights.
this has two more mounting points attached in the middle...
yes they do look nice but because all that weight is mounted on the two normal brackets, the top two lights do wobble quite a bit. i solved this by running a small bracket from the back of the top two lights, through the grille and into the front panel.
it stopped them wobbling but it was a pain when you wanted to take the grille off.
i took then off in the end because they were going rusty.
#3 mini25
mini25
  • 359 posts
Posted 20 February 2007 - 04:09 PM
i mean more like this
thnks for the reply
mini25
#4 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 24 February 2007 - 04:21 PM
Attached File  DSCN0559.jpg   641.08K   32 downloads
Attached File  SP_A0513.jpg   41.06K   28 downloads
Please excuse the rust, its undergoing a major rehaul at the moment.
#5 mini25
mini25
  • 359 posts
Posted 24 February 2007 - 08:18 PM
thats exactly what i mean, where did u get the brackets from?? shop/show/2nd hand
also how are they wired up? is it so that they only come on on full beam, or is there a seperate switch for them?
#6 1031 mini
1031 mini
  • 90 posts
  • Local Club: Me, myself and I
Posted 27 February 2007 - 04:02 PM
You can't be stealing my spots :'( ha ha only joking, just make some brakets, shouldn't be that hard
#7 Pie
Pie
  • 7,695 posts
Posted 27 February 2007 - 07:27 PM
Just get some metal abuot 1/4inch thick, cut it into long strips. Bend them, and then weld the pieces together.
I first put mine on last year, but removed them before THIS.
Ive just bought a works lamp bar, so ive got the choise of the 2up2down, or the 4across.
#8 mini25
mini25
  • 359 posts
Posted 27 February 2007 - 07:32 PM
ok kool guys cheers
#9 RacingGreen
RacingGreen
  • 2,111 posts
Posted 27 February 2007 - 07:53 PM
:dozing: i love the shameless plugging
#10 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 27 February 2007 - 09:06 PM
mini man pie are they cibie oscar lamps? if they are theyre the same as mine, really nice lamps but mine wobble a beaut!
#11 Al*
Al*
  • 1,476 posts
  • Local Club: ERC / SMOA
Posted 28 February 2007 - 05:51 AM
what exactly have you got them bolted to miniman pie.....?
Al
#12 Pie
Pie
  • 7,695 posts
Posted 28 February 2007 - 12:00 PM
RG, has to be done :dozing:
Marky Tizz- Yeah, top2 are Wipac lamps i bought brand new for £12 at the 3counties showground in malvern. And the bottom 2 are Cinie oscars 7" fog lamps. Bought them for £37including P+P
Al*- will take some pictures when im next up the lock up. They are made of steel though. PM navy seal as i know he made some.
#13 Al*
Al*
  • 1,476 posts
Posted 01 March 2007 - 06:48 AM
cheers m-pie..... will be waiting on those pics... and i reealise they ar emade of steel.... have a welder and all sorts of bar and rod so want to make a set.
thanks,
Al
#14 Pie
Pie
  • 7,695 posts
Posted 01 March 2007 - 12:58 PM
Attached File  2up2down_braket.bmp   1.6MB   99 downloads
A poor drawing i did on paint.
PM JetBlick and ask him to to do a cad drawing of 2up2down brakets
The brackets are make out of steel Bar abuot an inch wide and 1/4 of an inch thick if that helps at all.
#15 Al*
Al*
  • 1,476 posts
Posted 04 March 2007 - 05:51 PM
cheers for that one mininman pie although the drawing is a bit "sketchy" i think i can figure it out from the pictures and the drawing..... couple questions though... where it bolts to the bumper lip.... you take the bumper off then drill a hole through the lip and bolt it on..... does the bumper not foul when you try to re-install it..... as it has to sit over top of the two peices of 1/4" steel.....if at all possible to get pics of the actual brackets and the mount points on your car that would be awesome....
thanks.
Al
