Yet another Z cars haybusa mini
#16
Posted 21 February 2007 - 08:14 PM
also finally got all the fuel feed and return lines ect measured to length and run through the tunnel so have tie wrapped everything all together neatly to some tie wrap bases already bolted in the tunnel
fitted the fuel pump and high pressure filter under the bonnet and connected one end of the fuel line to this
and fitted the fuel pressure regulator at the rear,and connected this to the engine
fitted me exhaust manifold,need to get some more bolts for this though
and made a start on fitting the z cars loom,everything hides behind the dash which allows you to put the fusebox underneath and it has all the gauge feeds ect here,and then there are just 2 that go to the rear one for rear lights and one for the engine and 2 that go forwards one for the front lights and one for the front battery power,fan,horn,fuel pump ect
made a start clipping the rear lights in,decided to hide it under whats left of the parcel shelf and pop rivet the clips in so i can fit the bulkhead over the top
and down here
not sure what to do here though, there is another one to go to the engine down here dont know whether to put the carpet in and p clip them both on top or maybe put some sort of thin aluminium sheet boxing down here pop riveted to the inner sill and floor.Maybe ive been working on sites too long-could put a nice mdf boxing with skirting on the front! hmm
#17
Posted 21 February 2007 - 08:20 PM
#18
Posted 21 February 2007 - 08:24 PM
Looks awesome Oli, congratulations on the build and good luck with the fire-up!
Thanks tom,going to try and get a video of the first time i crack it up to post on here,never run it so might end up with egg on me face!!
#19
Posted 22 February 2007 - 08:23 PM
!!! only watch out for you brake line in your first picture, can give problems,....
looks nice mate
succes
#20
Posted 22 February 2007 - 10:27 PM
Keep it up!
René
#21
Posted 22 February 2007 - 10:51 PM
keep up the good work!
#22
Posted 24 February 2007 - 05:34 PM
Jacko299
#23
Posted 24 February 2007 - 07:33 PM
#24
Posted 24 February 2007 - 07:38 PM
Great looking car mate! where did you get your air filter from? did it come with a blank base plate because were looking to use one for an r1 keep up the good work!
Jacko299
Hi jacko got the air filter from z cars when i ordered a load of other stuff, the base plate wasnt blank it had 4 holes already in it,however i has to open them all out slightly to get the rubber rings in for me busa, but obviously they do R1 kits as well suggest posting in technical questions so z cars chris sees it, he will know a lot more than me, good luck with the build!
#25
Posted 24 February 2007 - 11:20 PM
#26
Posted 24 February 2007 - 11:50 PM
just noticed that you are from sheffield! whereabouts ? im just down the road in chesterfield, fancy a cuppa?
#27
Posted 25 February 2007 - 07:14 PM
hi oli ,
Hi ade, been working in dronfield today by coincidence!, i live in crosspool mate -a cuppa sounds very nice, im about next wk end,saturday if thats any good,pm me ya number - ill send mine your also welcome to come up if you want cheers oli
#28
Posted 26 February 2007 - 03:57 PM
#29
Posted 19 March 2007 - 10:59 PM
Started by connecting my modded bike loom
Tidied the loom a bit in here and decided it was better to put the fuseboard inside the dash here to make it easier to connect,will make an ally panel over the old speedo hole so i can get in to change to fuses ect should the need arise
Connected the fuel pump
And fitted the header tank
Also fitted the steering column and ignition switch
Made a new mount to fit my modded dash arrangment from a machined alloy block and a pair of hangers,these are just temporary when i have seats in ect i can make these any length to lower column and will paint them!
That whole lot is bolted through the dash like so, and its all totally solid now,unlike to standard arrangment which floats around the dash somewhat!
As i had an early front subby,mine had no hose mounts for the front brakes so pop rivited these on to hold the hoses..
And fitted the callipers and pads ect
Also finally connected rear brake lines and tonight filled and bled them with automec silicone brakes fluid
At the rear have made a start on the bulkhead which i got on a recent trip to z cars,and mounted the ecu and regulator
And as you can see fitted some floor carpets and sound proofing at the rear
And at the front including redrilling my gearlever which was wrong, and is now all connected so i have gears!
Also have fitted this bit so i have a throttle
And while at the front decided to slap a fan in and wired it in
Oh and while we are wiring fitted the rear lights
Phew thats enough for a bit, need to get some wiper stalks, doors ,a front end, lights bootlid ect fitted now
Edited by oli79, 19 March 2007 - 11:06 PM.
#30
Posted 20 March 2007 - 01:52 AM
