Dolly the 76 bay window camper
592 replies to this topic
#571 M44K TS
M44K TS
  • 3,104 posts
Posted 03 April 2011 - 10:50 PM
Good stuff Bungle, orange wouldn't have been my first choice for the engine, but it has a sort of Gulf colour vibe going on which I quite like.
Also, for the electrics, I know a good electrician that could sort that :)
#572 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 April 2011 - 04:34 PM
tightened the clutch cable a bit more and Dolly moves :D
only forwards and back a bit as the gear box hasn't got much oil in it
#573 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 April 2011 - 05:21 PM
filled with oil and everything seems to work :withstupid:
#574 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 12 April 2011 - 11:42 AM
we are on the road and working, done about 30 miles this morning with no problems
although the stop plate at the bottom of the gear stick needs a tweak
MOT tomorrow
#575 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 April 2011 - 05:54 PM
after a retest for a dodgy hand brake Dolly now has 12 months MOT :P
#576 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 16 April 2011 - 06:39 PM
Yeaaa go Dolly :P
Well done
#577 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 April 2011 - 05:55 PM
now Dolly works i got around to fitting some of my Christmas presents
mud flaps and jail bars
#578 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 September 2011 - 06:07 PM
i got really fed up of selecting random gears so today i took everything to bits, cleaned it up and looked for problems
i think the main problem is the intergalactic mileage my camper has done
i found the wear in these bits last time so had a go at doing something about it
all the bushes have been replaced from front to back again + the stop plate
i welded the wear on the pin (pictured above) up and using some emery paper and electric drill smoothed it out again
with the same emery paper smoothed the ball out and to take up the slack squashed the cup in the shift rod up a bit
putting everything back together (with new grease) was a struggle as everything is now a very tight fit
so far all 5 gears are there and in the right place and everything goes into gear with a very positive clunk
time for a test run tomorrow
#579 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 18 September 2011 - 08:09 AM
lovely bus bungle! looks like you done this one proud:)
have you put twin webers on it?!? thatsa crazy!
#580 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 18 September 2011 - 09:34 AM
Non-random gears eh? Sounds effieicnt. Or even efficient. How's it working now?
Edited by Teapot, 18 September 2011 - 09:34 AM.
#581 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 18 September 2011 - 02:55 PM
twin deli's
they have completely transformed the camper with loads more power and much better MPG
#582 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 18 September 2011 - 02:56 PM
not sure yet need to do a test drive and maybe a tweak
#583 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 23 March 2012 - 06:21 PM
look who i woke up today (with the aid of a booster pack) from her winter sleep
need some brakes and head lights before the MOT
#584 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 March 2012 - 09:32 PM
so while the sun was out and not long before we want to go camping i thought i would have a go at the rear brakes
things didn't go well
first flat battery
next i found i didn't have a socket big enough for the hub nut
after a bit of shopping and a larger socket set bought the hub nut still wouldn't come off
a trip to a work site and a scaffolding tube later the nut was off
next i snapped 2 fixing bolts (1 each side)
and finally after putting everything back together something is binding in one drum (gave up at this point)
the old ones stripped off
on both sides there was a bolt missing (snapped off) on the bottom fixing and while removing it i snapped off the other, so drilled out and retapped
new back plate on
and hub refitted + shoes
from the picture below you can see the whole outer rim of the back plates had rested away
#585 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 20 April 2012 - 09:43 PM
Thought i would in and say hello. Dolly looks great, what outings do you have planned for this year?
