i am in the middle of wiring my headlights for my flipfront and am wiring the main and dipped lights. Haynes says that one is a blue/white wire and the other a blue red wire but can anyone tell me which one of those is dipped and which is main beam please before i make a wild guess and connect them up wrong before it gets dark.
Daniel
headlight wiring colours?
daniel_johno
, Feb 13 2007 04:53 PM
4 replies to this topic
Posted 13 February 2007 - 04:53 PM
Posted 13 February 2007 - 04:58 PM
Hello Daniel,
This is what i've been told anyway:-
Wiring connections at the front of the car behind the grille:-
Earth is the Black wires
Sidelights are Red/Red with Green
Headlights are thick Blue with Red
Main Beam thick Blue with White
Posted 15 February 2007 - 08:50 PM
Is this wiring code set up the same for a Clubman? as i have tested my headlights and they seam to have two earths running off each headlight.. is this right or wrong??
Posted 15 February 2007 - 09:28 PM
clubman is slightly different because of the sidelights being below the lights rather than in them!
Posted 15 February 2007 - 10:43 PM
Clubman or not, I don't believe Lucas changed the basic color codes for high/low beams even between other British makes. Blue/White to the high beams sounds right.
A quick check is to attach a test lamp to your existing Blue/White wire on the car and switch on the ignition and light switch. If your test lamp is on when the dimmer switch turns on the dash high-beam indicator... you've got the right wire.
