Purple R1 Mini
#16
Posted 02 April 2007 - 07:16 PM
thanks, jacko 299
#17
Posted 02 April 2007 - 08:51 PM
The bulkhead only holds the rear quarters to the hoop, strengtheners could be fitted from the frame to the rear valence tho.
#18
Posted 03 April 2007 - 08:31 PM
jacko299
#19
Posted 03 April 2007 - 09:10 PM
.jpg)
Maybe an Idea?!
René
#20
Posted 04 April 2007 - 12:55 PM
#21
Posted 05 April 2007 - 07:37 PM
#22
Posted 05 April 2007 - 07:43 PM
#23
Posted 05 April 2007 - 07:47 PM
Thanks, jacko299
#24
Posted 05 April 2007 - 08:05 PM
#25
Posted 14 April 2007 - 04:38 PM
Made some alluminium panels to mount the dash and switches last night and today! nice weather to be working outside too
#26
Posted 22 July 2007 - 08:31 PM
Bit of progress from the last few months, bulkhead needs finishing but went for a drive round a car park earlier, was suprised with the amount of traction there is when accelerating in first! just digs in and goes!
Few pictures of a mates car from down the road, was down the himley show, one of the lowest cars ive seen! only came up to my waist! unfotunately his garage got broke into and a lot of parts from the car were stolen so its no stuck inside until the parts can be replaced! =[
#27
Posted 22 July 2007 - 08:39 PM
#28
Posted 22 July 2007 - 09:34 PM
ohh and think we may have a problem with the digi dash, when in use the rev counter rises as revs increase but then when backing off the rev counter reading drops until just under 2000 where it begins to stick, even if the engine revs still carry on dropping, it stays like this until the engine revs increase past the point the digi dash is stuck at but then the same happens again when backing off the throttle next time. anyone had anything similar happen??
ayup mate,
i connected the rev counter to one of the injectors (orange/black wire -pin 8 from ecu) it gives a smoother signal
then set digidash to 1 cylinder engine
Edited by adyzr1, 22 July 2007 - 09:42 PM.
#29
Posted 23 July 2007 - 09:40 AM
#30
Posted 23 July 2007 - 10:25 AM
Jackoahhh cheers mate, spoke to etb earlier and they say they have problems with the 2003 engine, have ordered a part from them that will hopefully cure the problem, he mentioned trying getting a feed from the injectors to if it still play up, thanks again
You will be better off using the feed for the injectors as ady says. The reason behind this is down to the pulse signal to the
on-plug coils. Voltages can linger about in these type s of coils giving false info. I don't know why ETB instruct to use the coils.
You could even use the original signal wire from the ecu.
