What Mini Do you Drive?
3087 replies to this topic
#2986 imack
imack
  • 2,197 posts
Posted 18 May 2020 - 11:55 AM
Hello,
I'm new to the forum, so here goes....
I have a 1980 Clubman, that is currently undergoing a bare metal rebuild. It was build as a rally car by a friend around 30 years ago, before being damaged in an RTA while he was driving to work. I bought all the bits, and planned to restore it, but the project stalled and the car was put into storage until Jan this year.
I had planned to compete on the Mull Rally in October this year, but I think that it will be 2021 now.
The shell has a Safety Devices 19 point bolt-in cage, flip and removeable steel front with opening bonnet.
I will be running the VeTech wide track and brake conversion on the front, with VeTech rear hubs and backplates, KAD rear arms with custom stub axels and brake backplate spacers to wide track the rear.
The engine is a 1330cc A+ block with MED crank, large centre main strap and flywheel. The head, pistons and cam kit are from Keith Calver. It will be running the Specialist Components 5-port injection kit, and the MED front mounted cooling setup with electric water bump and dry deck setup.
Think that's it in a nutshell.
Andy
My friend lives on Mull, those roads are awesome.
#2987 Andy_Chezz
Andy_Chezz
  • Just Joined
  • 0 posts
Posted 19 May 2020 - 09:02 AM
Hello,
Andy
I have been visiting Mull since the early 90's, and have serviced for numerous crews on the event over the years. I decided it was high time I actually did the event to see what all the fuss is about.  :lol:
#2988 Anna07
Anna07
  • 0 posts
Posted 22 May 2020 - 12:37 PM
What mini do you drive and are there any mods done to it ?
Also what are your plans http://www.theminifo..._DIR#/smile.png !
#2989 Anna07
Anna07
  • 0 posts
Posted 22 May 2020 - 12:42 PM
Hi I have a1989 mini with all new interior hi lo's fitted new exhaust new wheels plus loads of other new parts. Getting car ready for respray.
#2990 Redback
Redback
  • 0 posts
Posted 31 May 2020 - 12:01 PM
Hi   I bought a 1963 850 in October last year.  My first Mini although I have had a number of British classics over the years. I am the fourth  owner and it has always been a local car (Canberra Australia). it had a restoration about ten years ago ( previous owner). Now has a 1275 and Leyland gearbox cooper S disc brakes twin fuel tanks Toyota MR2 seats plus plenty other mods. Goes fabulously although the exhaust has a bit of a drone so might think about a slightly quieter muffler especially for highway driving. It is in excellent condition and I intend to keep it more or less as it is.
#2991 nathan crawford
nathan crawford
  • 0 posts
Posted 06 June 2020 - 11:16 AM
I have just recently purchased a i believe 1995 rover mini 1000 its a non runner but hopefully wont take much to go its mostly blue excluding the front wings with are black primer.
its got a full set of alloys, wide arches and a straight pipe.
needs a drivers side sill
looking to get it road worthy before my 17 birthday
#2992 flash_1275
flash_1275
    Starting My Mini Up
  • 2 posts
Posted 09 June 2020 - 03:35 PM
Hmm … it used to be a  metallic-maroon 1992 Rover Mini Sprite.
Someone before me took out the 1275 engine, but did a whole host of mods with body kit and full-black respray externally, electric windows (aargh, electrical nightmare), electric locking (aargh, another electrical nightmare), and other jobs that appear to have been reversed/removed by other owners … there are dozens of dead-end wires switches/buttons that don't seem to be connected to anything!
And now something's gone in the ignition circuit; goAttached File  AMG_3329.jpg   69.5K   0 downloadsAttached File  AMG_3324.jpg   83.85K   0 downloadsing to have to ask for help! (forgotten how to check and identify the fault!)
#2993 exuptoy
exuptoy
  • 674 posts
Posted 03 July 2020 - 11:27 AM
Hello,
Andy
Nice spec.
#2994 Marriott
Marriott
    Starting My Mini Up
  • Validating
  • 3 posts
Posted 14 July 2020 - 07:30 PM
New to the forum =]
I've just bought a 1989 Mini City and I'm currently in the process of restoring it.
hopefully as a first car.
#2995 BrunswickMini
BrunswickMini
    Starting My Mini Up
  • 1 posts
Posted 15 July 2020 - 07:34 AM
Hi,
My little car is as follows;
1989 Sky Rose 1330
Miglia arches
13" Superlights
Adjustable lower arms/tie rods/poly bushes
Koni adjustable dampers/HiLo's
21253 +60 pistons, 8cc dish
286 cam
HIF44 with BDL needle
LCB with maniflow system
Engine currently out being rebuilt, I've just had the head converted to unleaded.
Will gas flow it, larger valves etc.
I'm going to investigate lightening the crank and balancing it, need to get some photos of a SH crank if possible.
I have a set of completely rebuilt HS4 twins to go on, maniflow tubular inlet.
Looking to put on Maniflow LMSII race headers and make my own stainless system.
Will need to rebuild gearbox, considering an LSD or at least a cross pin diff for time being.
Once I have engine in, i'll get it set up on our rollers and set chassis geometry up and corner weight it.
Should go well, i'd like bigger power (115-120bhp) but not sure the wife will like the lack of bottom end and 8k limit.
#2996 topherwillis
topherwillis
    Starting My Mini Up
  • 2 posts
Posted 09 August 2020 - 08:15 AM
I recently purchased a 1994 JDM Rover Mayfair 1.3i. This is my first Mini and my first project car. I am enjoying the mechanical aspects of fixing it up, but the electrical system is a nightmare.
#2997 RogerJJW
RogerJJW
  • 10 posts
Posted 11 August 2020 - 08:03 AM
Hi, Good to meet you all 1997 Cooper MPI just finished a long shell restoration and spray job , did mechanicals before hand just in countering some teething issues lol
#2998 ForstalJim
ForstalJim
    Starting My Mini Up
  • Just Joined
  • 2 posts
Posted 19 August 2020 - 10:54 AM
I am restoring a 1974 mini pick up.
#2999 ForstalJim
ForstalJim
    Starting My Mini Up
  • Just Joined
  • 2 posts
Posted 19 August 2020 - 11:03 AM
Good afternoon.
I have just joined the forum.
I think I may need some guidance on some of the work which I hope will come from members of the forum.
#3000 COoPeRbOI
COoPeRbOI
    Starting My Mini Up
  • 1 posts
Posted 29 August 2020 - 10:09 AM
Hi People,
just got a 1968 Cooper mk2, and am planning on doing a full nut and bolt restoration on it and maybe i will be putting a Swiftune race engine too
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
