What Mini Do you Drive?
3088 replies to this topic
#2971 JamesRo1293Trex
JamesRo1293Trex
  • 10 posts
Posted 15 April 2020 - 03:32 PM
Hi,
I'm restoring a 96 MPi currently. Building it with specialist components 5 port efi kit and S Pack with a rotrex aiming for 180+ bhp.
Give me a follow on 1293_grey_mini
J
#2972 Rocky1
Rocky1
    Just On Tickover
  • 6 posts
Posted 18 April 2020 - 08:34 AM
Hello,I have only just joined,I'm restoring a 1983 mini sprite,Attached File  20190428_204107.jpg   63.26K   0 downloads
#2973 Scaton9
Scaton9
    Starting My Mini Up
  • 1 posts
Posted 20 April 2020 - 09:38 PM
Just on with restoring a 1974 mini 1275 gt 90% finished always looking out for mini bits
#2974 JBirch
JBirch
    Starting My Mini Up
  • 1 posts
Posted 02 May 2020 - 10:42 PM
I have a 1994 Classic 35 1.3i with only minimal upgrades. It’s mostly stock. I put heavy duty tie-rods on, KN filter and that’s about it. I have replaced the ball joints, constant velocity joints, replaced the selector shaft o ring, installed a new stepper motor, replaced valve stem seals, boiled out radiator and author stuff. I’m about to put a new battery in, the old one was a 2009. I’ve always kept a battery tender on it in the garage.
#2975 Jaammeess77
Jaammeess77
    Starting My Mini Up
  • 1 posts
Posted 03 May 2020 - 07:41 PM
Hey,
I've got a 1989 mini 30,
She was purchased a few years ago as my first car, however she has unfortunately been off the road for the last year with a few minor problems,
Hoping to be driving the mini on the road again this summer.
#2976 Rivin
Rivin
  • 10 posts
Posted 04 May 2020 - 09:40 AM
I have 93 rover 1300 efi spi wirh automatic gearbox,, newbie in the world of mini ,, from Philippines
#2977 Mark B
Mark B
    Starting My Mini Up
  • 4 posts
Posted 06 May 2020 - 08:54 PM
1972 MK3 mini, no seams on 10" rose petals, 1310cc supercharged and fuel injected
#2978 ntvrman
ntvrman
    Starting My Mini Up
  • 3 posts
Posted 07 May 2020 - 03:31 PM
Hi,
i own a 1979 clubman 1275 GT, which I started to restore about 10 years ago, but have been sidetracked for a fair while with other life issues. Most of the underside has been sorted but engine in need of rebore due too stuck pistons and damaged bore. I’m told I need to replace the pistons with +20 ones. Trouble is funds are tight. Also the standard ones are fine, just no use once the rebore is done.
just wondering if there’s a possibility of a swap plus cash,with a member on here.
ntvrman
#2979 Landyboy007
Landyboy007
  • 29 posts
Posted 08 May 2020 - 07:30 AM
I have just bought a 1985 mini Mayfair and plan to strip it completely!
#2980 richo2902
richo2902
    Starting My Mini Up
  • 1 posts
Posted 10 May 2020 - 11:47 AM
Hi, I have a 1973 mini 1000 , bought it 2 years ago non runner, complete but been stood outside for some years, many people would say its a basket case but i like a challenge!. I am in Nottingham.The car is about 75% finished, the only change is a 1275 engine, 10" disc brakes . Its had probably 75% of the body panels renewed.
#2981 Iain Heatlie
Iain Heatlie
    Starting My Mini Up
  • 1 posts
Posted 14 May 2020 - 05:09 PM
Probably a bit off piste but its a BMC Mini tractor with a 948 diesel engine
#2982 stevewes
stevewes
  • 16 posts
Posted 14 May 2020 - 06:53 PM
1984 registered mini with 1994 rust free shell. 1407 cc engine with Nitrous oxide injection.
I'm confused - surely if you have a 1994 shell then you have a 1994 registered Mini.  Unless you're saying you have a ringer - surely you wouldn't be admitting that on a public forum ;D
#2983 allotmentboy
allotmentboy
    Starting My Mini Up
  • 1 posts
Posted 16 May 2020 - 01:56 PM
i drive a mini1000 with a 1310 engine fitted
#2984 moogle
moogle
  • 0 posts
Posted 17 May 2020 - 09:12 PM
My Very First MINI! She is a 1994 Rover Mini Sprint. She is White with a black wing as she has a fair bit of rust on her. I would love to get her full able to be my daily driver. I have a fair amount of work. She currently runs however just TODAY she dropped her exhaust on a run around the bay after an oil and spark plug change. She is a fun little thing and I can't wait to jump in. My wallet however might say otherwise.  :lol:  :gimme:  :D
#2985 Andy_Chezz
Andy_Chezz
  • Just Joined
  • 0 posts
Posted 18 May 2020 - 10:52 AM
Hello,
I'm new to the forum, so here goes....
I have a 1980 Clubman, that is currently undergoing a bare metal rebuild. It was build as a rally car by a friend around 30 years ago, before being damaged in an RTA while he was driving to work. I bought all the bits, and planned to restore it, but the project stalled and the car was put into storage until Jan this year.
I had planned to compete on the Mull Rally in October this year, but I think that it will be 2021 now.
The shell has a Safety Devices 19 point bolt-in cage, flip and removeable steel front with opening bonnet.
I will be running the VeTech wide track and brake conversion on the front, with VeTech rear hubs and backplates, KAD rear arms with custom stub axels and brake backplate spacers to wide track the rear.
The engine is a 1330cc A+ block with MED crank, large centre main strap and flywheel. The head, pistons and cam kit are from Keith Calver. It will be running the Specialist Components 5-port injection kit, and the MED front mounted cooling setup with electric water bump and dry deck setup.
Think that's it in a nutshell.
Andy
