ROD
Posted 16 January 2007 - 08:07 PM
Posted 16 January 2007 - 08:11 PM
Posted 16 January 2007 - 08:12 PM
Posted 16 January 2007 - 08:50 PM
Posted 16 January 2007 - 08:53 PM
My Thoughts Exactly, Hence My Original QuestionYou can NOT tow an automatic. It must be moved on a trailer or A frame so the front wheels are off the ground completely. If not, you'll knacker it.
Posted 16 January 2007 - 11:39 PM
Edited by Dan, 16 January 2007 - 11:40 PM.
Posted 17 January 2007 - 10:07 AM
What Do You Mean? Via Trailer, Rope, Or One Of Those Flash Car Puller Frame Things What You Have On The Back Of Motorhomes?
Posted 17 January 2007 - 10:12 AM
Depends on the age. Early auto Minis can be towed as the gearbox has a towing oil pump driven by the diff, they can even be tow started. I think the end date for this is '73 but I'm not sure.
HOWEVER it should be pointed out that it is not legal to tow a car like this except in an emergency to get it out of traffic. Unless you can physically turn the car into a braked trailer (or an unbraked trailer if your towing vehicle is heavy enough to do this legally) you can't tow it and I don't think A frames are allowed to be used for this anymore (we can't use them at work on the road anymore, only on closed roads). So if you need to move a car 50 miles, you need a car trailer anyway.
And by the way, an A frame doesn't lift the front wheels and will still knacker an auto that doesn't have a towing pump.
Posted 17 January 2007 - 09:04 PM
Posted 17 January 2007 - 09:55 PM
Posted 18 January 2007 - 08:50 AM
