Brace Bars - Making Your Own
Posted 16 January 2007 - 06:28 PM
This weekend I visited a new Mini owner in my area. His project car has a fiberglass front end installed by a previous owner. They left the inner wings but provided no additional bracing. The following questions are technical, not legal, so please comment but don't remind me what's necessary for MOT since it doesn't apply in this case.
1) Is this car at risk without brace bars? Do they significantly improve the front end stiffness?
2) The round-nose brace bars I've seen pictures of have a bend in them. I haven't studied the front end of this car in detail... but why is a bend necessary? Couldn't subframe mounting/attachment tabs be made longer so the bend in the square tubing can be omitted?
3) If anyone has made their own bars, did you keep any sketches or drawings you could share? I can make my own but would prefer to learn from the experiences of those who've dealt with this before.
I know the bars can be bought and the current price at Mini Spares is only about 23 GBP. However, after shipping/carriage charges that will be rather a lot of money... especially since it's not my car. (I can buy them over here from Mini Mania but they sell them for about $86... roughly twice what you guys pay... plus I'd have to ship them across country, probably another $20)
Posted 16 January 2007 - 08:39 PM
Posted 17 January 2007 - 02:19 PM
Posted 30 July 2007 - 11:12 PM
also if you did make your own bars have you got any drawings that you could share with me. i would prefere to make my own too. just to say i did
many thanks in advance Robert.
Posted 31 July 2007 - 07:16 AM
However if I was making my own I would make them out of straight round tube with a rose joint at each end. Especially at the rear side of the engine where it would make clutch work even simpler as two nuts and the brace bar could be removed for improved access. Where a front mounted rad is used in the miglias they run the bracing from the bulkhead cross member rather than the outside of the inner wings.
If you use straight box section (ie no kink) there may be an issue with the wheels catching on full lock? Especially with big rims or lowered cars. Also they may look odd being far away from the subframe corners.
Posted 31 July 2007 - 07:25 AM
Posted 31 July 2007 - 07:27 AM
one time in a rush to get an MOT(on my own car) i used inch by inch angle , it bolted on easier and was well up to the job , not as pretty though .
Posted 31 July 2007 - 07:32 AM
The front support bar provide support and control over the front of the subframe ( basically providing the same fuction as the valance and inner/outer wings.
As for the kink, I would believe that it's mainly for esthetic reasons but you may also experience clearance problems on the front end panels when fitted.
Posted 31 July 2007 - 09:35 AM
Posted 31 July 2007 - 09:46 AM
I'd be inclined to put the front end of the brace a little higher and cut 'n shut it to give a vertical section at the front in an attempt to dissipate any head on impact loads better.
Posted 31 July 2007 - 11:57 AM
My question was posted for another local Mini owner who has no money but owns a Mini with a fiberglass front end.
TomF, is your brace bar guide in a format that can be emailed? If so, let me know and I'll send you my address also. My friend has even less money to spend on this now but when he can get the material together I'm sure he's still interested in stiffening his car's front end.
Posted 11 May 2012 - 03:31 PM
Posted 11 May 2012 - 04:35 PM
Posted 11 May 2012 - 04:49 PM
It the bar didnt have a bend in it, the tab would be a good 6 or 7 inches longer than it needs to be, reducing the stiffness of the bar. It would also be very close to the wheels on full lock without the bend.
Also, it had to be done
Posted 13 May 2012 - 07:18 PM
