Oil pressure warning light
Posted 07 January 2007 - 11:23 PM
Posted 07 January 2007 - 11:27 PM
First thing to try is change the oil and filter and fill it with a good quality 20W/50.
Also sniff the disptick *yes I said that right* and if it smells of fuel then the diaphragm on your fuel pump may have split and allowing fuel into the crankcase.
Posted 07 January 2007 - 11:30 PM
the cup gets scored and can stick
Posted 07 January 2007 - 11:31 PM
Posted 07 January 2007 - 11:57 PM
Posted 07 January 2007 - 11:59 PM
You sure it's not the no charge lamp? What colour is it? The oil pressure lamp can't really flicker dimly, it's either on or off. It just has a basic switch driving it rather than a resistance and to be dim it would need to be flicking on and off very quickly, which it can't really do.
its an orange light.
Posted 08 January 2007 - 12:04 AM
ok ill give her an oil and filter change and see whats happens. ive smelt the oil and it smells fine. also something else is buging me, coming off the inlet manifold is a 3/4 inch rubber pipe, with a recess on the oppsite side the same as the one as the pipe back this one is pipeless. however the pipe doesnt go anywhere its just sitting across the rocker cover like a numpty.
does this pipe go to the manifold or the carb, if it goes to the carb, then its the breather pipe and it should be connected to the breather at the back of the engine.
Posted 08 January 2007 - 12:06 AM
Posted 08 January 2007 - 12:14 AM
cheers cowboy
Posted 08 January 2007 - 12:32 AM
As you suspect, amber is oil pressure. It could be that the pressure is right exactly on the limit of the switch which is 7 psi as standard and not good, even at idle. Needs investigating as said above.
Posted 08 January 2007 - 12:44 AM
also i have two extra cables which are not connected and are just lying there.
Posted 08 January 2007 - 12:57 AM
The pipe with the screw blocking it off in the 2nd pick is used for a vac gauge or similar. Gauge is avalible from mini spares or you can leave it off.
by the way i THINK its a metro manifold. I'll look it up.
edit
if them "random pipe" are not connected then you can always get a meter or two of heater pipe to rig them up. You splice it in with the heater circut. So inbertween the heater tap (or take off on the cylinder head) and the heater or the heater and the bottom house.
edit
yeah, looking in the vizard book I'd put money on it being a MG metro manifold. or at least a copy.
Edited by Big_Adam, 08 January 2007 - 01:02 AM.
Posted 08 January 2007 - 01:12 AM
Edited by Grease_monkey1986, 08 January 2007 - 01:18 AM.
Posted 08 January 2007 - 01:48 AM
Also engine colour doesn't really mean much...well don't think it does as El Gordo's is yellow.
As for the manifold it could have just come off a metro to be put onto your mini as they fit and are suppost to be the best flowing that BMC made or somthing to that effect.
Posted 08 January 2007 - 10:17 AM
The two things you have marked as cables appear to be the heater control cable (the cable running accross the rocker box) which should be connected to the heater control valve and the vacuum advance hose (the pipe running front to back) which should be connected from the vacuum outlet on the carb (not the manifold union which is plugged) to the vacuum advance on the dizzy. If this is just flapping about it will allow the mixture to lean out as the carb port will be allowing extra air in.
If it's original paint then yellow means it's an A+ 998. Or it could be anything that's been painted yellow by someone.
