Yamaha R1 carbed A series Mini
#121
Posted 20 March 2007 - 01:12 PM
It's a BIG task for me, but I really want the head to be one of my own creations! The only thing I don't have the facility to do is the 3 angle work, so I'll have to go to a machine shop for that.
#122
Posted 20 March 2007 - 01:18 PM
Just rang minispares North to order valves but no answer? Will try later
#123
Posted 20 March 2007 - 07:19 PM
Got my discount thou so all okay
Finally got some enthusiasm back for getting it all back together
#124
Posted 21 March 2007 - 12:43 PM
Right got the new valves ordered but had to order them from Minispares main as North office has a big delivery £85K in so wont be sending out any deliverys for the rest of the week.
Excellent! Keep us updated
#125
Posted 22 March 2007 - 07:02 PM
First one is fitting Megajolt. I have already fitted the trigger wheel and the VR sensor bracket. I have been waiting to fit the bike carbs so that I can wire in the TPS off the carbs, just need to find/buy the Yamaha plug off the bike wiring loom and sort a final +ve and -ve.
Other thing I am going to do is remove the full width dash, I've never been overly happy with it but didnt think I had much choice due to the weber box, I've since had a few ideas I'm not saying to much at the minute but hopefully no one else will have done the same. Just need to check a few things out before final fitting
Lastly I'm going to be changing the wheels for some old skool 10" wheels once I find someone local to refurb them and I also have to run up some wheel centres on a lathe as I cant find any off the shelf that fit. Need to sort some brakes as well as currently on 12" wheels, probably Cooper 'S' or if the money is available some 4 pots of some sort
Final thing is here are a couple of pictures of the car as is, just as I havent posted any up before.
seats are now cobra classics but for some reason dont have recent photos?
Cheers for now
Edited by Udo, 23 March 2007 - 11:11 AM.
#126
Posted 23 March 2007 - 07:10 PM
Just remembered I need a new heater tap so that may hold things up till mid week as havent ordered it yet!
#127
Posted 24 March 2007 - 11:18 AM
#128
Posted 24 March 2007 - 06:26 PM
Got the head back together and fitted today, just got rockers to adjust tomorrow and refill with coolant then fingers crossed!
I think I was right in that the adjustable ream wasnt up to the job and didnt ream them to the correct size as a few of the guides needed quite a bit (as in a few thou) taking out.
#129
Posted 25 March 2007 - 11:27 PM
#130
Posted 26 March 2007 - 11:47 AM
Going to hopefully sort tonight, need a rear wheel bearing split pin thou as took the drum off for another reason. Halfords on way home probably
#131
Posted 31 March 2007 - 06:19 PM
New inlet valves bought exhaust ones also but forgot to get picture
Also while waiting for heater tap I made a small start on a new accelerator pedal to reduce the amount of cable that is pulled to better suit the bike carbs
cheers for now
#132
Posted 17 April 2007 - 12:48 PM
#133
Posted 17 April 2007 - 11:11 PM
Also got a bit further on with one of the other projects on this car - photos will follow at some point soon
#134
Posted 19 April 2007 - 11:39 AM
#135
Posted 19 April 2007 - 02:19 PM
Got your pedal welded yet? Did you guess or work out how much to adjust it by? Was it enough of an adjustment?
