Cheers for the comments Dan, even if most of the pages arent to do with the bike carbs! -You buying the KAD back by the way? Loved the last fly by vid you posted
Head work was all done at my relatives garage on a clean engine build bench, was very very careful with keeping everything clean. After reaming head was blown over throughly with an air line in a different room. The same with all the valves after cleaning them up.
Got the head off again and all apart, valve that stuck wasnt any longer so must have stuck got hit by piston which bent it and also freed it off again.
Have decided to buy a new proper non adjustable ream, the one I used before was an adjustable one and although I checked the size quite a few times and also between reaming each guide it MAY have not been exactly the correct size. I'll run the ream thru but I may find I need new guides again but wont know until I get the ream
I am also going to order a full set of new valves tomorrow so should be with me by the weekend as should the ream
By the way how do I get the Minispares discount?
Edited by Udo, 20 March 2007 - 12:02 AM.
