Well,
Got on the rollers, warmed up and then started running up the rev range.
Got up to 80bhp at wheels at 5000 (previous with weber was 84 at 6000) then number 8 exhaust valve stuck and has bent the valve as per the previous one
Upto that point it was running very well and I cant figure out why a valve has stuck again, or what the solution to whatever the problem is.
Do I buy all new valves or just sod it and buy a new head?
This is really sttarting to
me off, only good thing being the power seems to be there as it will quite happily rev to 6500 so virtually the same power as before but lower down the range and with a lot more low down torque. I'm assuming that the power will at miniumum be the same as before. I dont think it will be going back on the rollers as we had sorted all the fueling etc just hadnt done a final power run
Dumped the car in the garage and shut the door, really cant be bothered to look at it at the moment
