Yamaha R1 carbed A series Mini
175 replies to this topic
#46 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 13 January 2007 - 01:15 AM
i've just returned from the autorport international, chatted with a few folks there about throttle bodies and injection only the important people, dta, jenvy, etc. anyhoo, the gist i got was if it puts in fuel and air at the right rate then it'll work. how well depends on the complexity or adjustability of the carbs interior!
#47 Udo
Udo
  • 1,670 posts
Posted 17 January 2007 - 02:28 PM
Finished painting the inlets up last night with high temp paint.
Just amassing the bits required for saturdays rolling road
Carbs (rather obviuosly)
Inlets
Airfilter
New throttle cable
Choke cable is okay to reuse
New inlet manifold gasket
New sparkplugs just in case (leads are ok)
Rocker cover gasket (as rocker clearances need checking and not sure of condition of existing gasket)
Camera
Oil and coolant checked
Anything else?
#48 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 17 January 2007 - 03:09 PM
Full tank of fuel? Just so you dont run out whilst on the rollers? :gimme:
#49 Udo
Udo
  • 1,670 posts
Posted 20 January 2007 - 07:01 PM
Well good news and bad news following the rolling road!
Fitted carbs turned key and it started :-
Started to do a few runs at differrent loads etc needed to adjust the main jets and blank off the air correction jets, slowly working the way up the rev/load range but there was a misfire. Each time we adjusted something it moved a little further up the rev range.
Then Paul, the operator, said it was cylinder 3 that was misfiring. Fair enough I thought as had a new set of spark plugs with me. Put them in but no better so took nr 3 plug out looked into the cylinder to see a trickle of coolant down the back of the bore :w00t: :genius: :genius: :xxx: Head gasket has gone
Anyway packed up the rolling road equipment, and drove it home to fix and although the head gasket has gone the noise compared to the weber is less and it will pick up quicker and smoother when saying doing 30 in 4th and putting your foot down.
Once head gasket is done It will back on the rolling road.
#50 ed4ran
ed4ran
  • 2,849 posts
Posted 20 January 2007 - 09:13 PM
LOL, funnily enough i know how you feel :- seems like theres always something!!! :w00t:
Are you going to get a vid of it on the rollers?
#51 Udo
Udo
  • 1,670 posts
Posted 21 January 2007 - 12:19 PM
Will do when I get a decent run in!
Sort of had a feeling something wasn't going to go right when I cross threaded one of the manifold nuts.
#52 ed4ran
ed4ran
  • 2,849 posts
Posted 24 January 2007 - 12:50 AM
Got the head gasket changed yet? :D :)
#53 Udo
Udo
  • 1,670 posts
Posted 24 January 2007 - 12:27 PM
Not yet no as while the head is off I'm going to be giving it the once over which has resulted so far in -
that I need new head studs as one is bent (probably caused the gasket to go) :D
the rocker shaft is scrap! :)
the pads on the rockers are suspect, probably due to the shaft being scrap! :o
and I still need to check the valves and guides which I'm doing sat down PRP.
Going to Bingley with cash as I suspect the easist way to sort the rockers is to get some new ones but don't want 1:5 ratio ones really and nobody seems to make standard 1:3 ones any more.
Edited by Udo, 24 January 2007 - 12:27 PM.
#54 ed4ran
ed4ran
  • 2,849 posts
Posted 24 January 2007 - 01:10 PM
Are they roller ones or standard ones?
#55 Udo
Udo
  • 1,670 posts
Posted 24 January 2007 - 01:24 PM
They were the old pressed steel ones which had been strengthened by welding them as per Vizards
Really stuck as to what to get dont think they are salvagable as the pads would need grinding down which I think would remove the hardened surface which would make them useless
and If i go up to 1:5 it will make the cam come in later which I dont want plus they wont fit under the standard steel rocker cover
#56 fikus01
fikus01
  • 1,910 posts
Posted 24 January 2007 - 08:50 PM
wouldnt necesdarily make the cam come in later!! what cam are you running? 286 with 1:5's is about as hard on power as its guna get at 2500rpm, definately 3000rpm but its barable under that as long as u have the right dizzy giving the right timing!
Edited by fikus01, 24 January 2007 - 08:51 PM.
#57 Udo
Udo
  • 1,670 posts
Posted 25 January 2007 - 12:07 AM
but one of the points of the bike carbs was to improve the low down torque which going to 1:5 would be going the wrong way moving the point it which in comes on cam
and the issue of the rocker cover, not major but I really dont like the alloy/MG ones you get
#58 fikus01
fikus01
  • 1,910 posts
Posted 25 January 2007 - 12:35 AM
hmm, again it depends on cam choice really, a std cam will give better torque at low revs with 1:5 i was lead to believe because a std cam is so short on lift!
#59 Udo
Udo
  • 1,670 posts
Posted 25 January 2007 - 10:03 AM
Currently running a 286
#60 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 25 January 2007 - 06:34 PM
unless ive missed it,
what specs the innerds of your engine......
looking amazin! cant wait for the results of this!
