How Do You Take The Sills Off
47 replies to this topic
#16 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 27 January 2007 - 01:03 PM
Any pics yet?
#17 Jammy
Jammy
  • 25,397 posts
Posted 31 January 2007 - 10:44 PM
I started this tonight, so will get some pics up. Started drilling the spot welds that connect the bottom of the sill to the floor pan, then noticed that there is a spotweld every 1.5cm along the sill to rear quarter/door step seam! I thought, bugger that, I ain't drilling all them!
#18 mkw
mkw
  • 1,003 posts
Posted 01 February 2007 - 10:05 AM
Sounds like fun!! Can't wait for the pics, gonna be useful to a lot of people.
#19 black jack1275
black jack1275
  • 276 posts
Posted 01 February 2007 - 01:16 PM
Sorry to jump in jammy :P i have some pics i did for another forum Aaron
Edited by black jack1275, 19 December 2007 - 08:22 AM.
#20 Jammy
Jammy
  • 25,397 posts
Posted 01 February 2007 - 03:20 PM
Oooooo, thats a very good diagram, thanks!
#21 mkw
mkw
  • 1,003 posts
Posted 01 February 2007 - 03:37 PM
That's gonna be useful for when i get round to it!!
#22 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 February 2007 - 04:27 PM
Get youself one of these, since I got one could not do without it, all you do is center punch the sport weld and then cut out the metal around the spot... This leaves a little dimple of metal still attached which can be taken off with a sanding disk in an angle grinder... this means you not actually drilling any holes in the metal which is remainging...
http://www.machinema...spot-weld-drill or
#23 Jammy
Jammy
  • 25,397 posts
Posted 09 February 2007 - 11:43 AM
Right, I cut most of the sill off last night, but had to cut around the jacking point in the middle. Are the more spot welds in this or what?
#24 black jack1275
black jack1275
  • 276 posts
Posted 09 February 2007 - 12:05 PM
jammy there were about 6 spot welds around my jacking point and they can be a PITA to get off +some numpty had welded around the hole in the jacking point so i had to grind that as well
New pic to show were the spot may be (good luck Aaron)
#25 black jack1275
black jack1275
  • 276 posts
Posted 09 February 2007 - 12:07 PM
the red dots :angel:*
#26 Jammy
Jammy
  • 25,397 posts
Posted 09 February 2007 - 12:27 PM
Yea, got all them. I've cut all the sill off around the jacking point, and now it literally is just that bit that left on?! :S
#27 black jack1275
black jack1275
  • 276 posts
Posted 09 February 2007 - 12:37 PM
when i put the new sils on my car i had drilled all the way through the inner/outer sills, then when i put the new sill into place i welded it from the inside of the car, a lot better and you are not on your back all the time
#28 Jammy
Jammy
  • 25,397 posts
Posted 09 February 2007 - 12:45 PM
Well the shell is currently bare and resting on its side, so I'm working at head height.
But I'm still not sure how to get that jacking point off...?!
#29 black jack1275
black jack1275
  • 276 posts
Posted 09 February 2007 - 12:50 PM
Your lucky i spent 4 days on my back doing my sills
As for the jacking point it is spoted to the inner sill
#30 Jammy
Jammy
  • 25,397 posts
Posted 09 February 2007 - 12:57 PM
Oh right, so you take the whole thing off? The outer sill doesn't come away from the jacking bit?
    Bing (1)
