How Do You Take The Sills Off
Posted 05 January 2007 - 12:07 AM
Posted 05 January 2007 - 12:10 AM
wats the best way of taking old sills off
angle grinder, pry bar and a big hammer????
Posted 05 January 2007 - 12:12 AM
Posted 05 January 2007 - 12:13 AM
Posted 05 January 2007 - 12:17 AM
Posted 05 January 2007 - 12:22 AM
Posted 05 January 2007 - 12:23 AM
Posted 05 January 2007 - 05:56 PM
Posted 05 January 2007 - 06:08 PM
but with a grinder
Posted 05 January 2007 - 07:23 PM
Posted 05 January 2007 - 07:34 PM
then bend the sill down
Posted 05 January 2007 - 10:37 PM
old sill leaving about 20mm overlap, then cut out old sill with a grinder,
or air saw (if you have one), cut the old sill along the length where it is
folded (where it joins the door step)
Posted 05 January 2007 - 11:06 PM
best way is with a spot weld drill just remove all the spot welds on the seam and the inner sill and a few smacks with an hammer and chisel should do it unless it as rubbish over sills onhold replacement sill over old sill, mark round the sill then remove, remark
Posted 22 January 2007 - 10:14 PM
Posted 23 January 2007 - 08:48 AM
The sill seam ( where it joins the rear quarter and doorstep ) is welded the same way as the roof with a rolling spot welder so needs to be cut below the seam..
I recommend the use of 1mm disks for cutting, it's quick and accurate, and then a sanding disk on the grinder to remove the remaining metal and spots. basically you want to end up in the position where you have the floor pan and door step/rear quarter fully exposed ( as you're likely to have to replace some of this too
Bing (1)
