Using way too much fuel
Posted 03 January 2007 - 12:18 AM
I've done a few searches (though searching for fuel and petrol is a needle in haystack :'( ) and all i could find was a suggestion to give it a service. I'm going to replace the oil and flush the radiator tomorrow, but is this likely to make any difference? I can't afford to get it rolling roaded atm, but i also can't keep spending this kind of cash on petrol. Anyone have any suggestions to sort out this problem?
Anything else you need to know, I'll answer as best I can.
Thanks boys!
Posted 03 January 2007 - 12:33 AM
might be worth putting some fuel additive in to clean injectors / jets, are you doing town driving or motorway miles ??
Posted 03 January 2007 - 12:35 AM
by checking the timing and also take the plugs out to see what colour they are. Im guessing they're
gonna be blackish which means the mixture is too rich. The mixture will need adjusting, seems like
maybe you should get a garage to do it as they will have the experience to do it for you in a few minutes.
Posted 03 January 2007 - 12:39 AM
Just a mystery of the univerce.
Posted 03 January 2007 - 07:01 AM
Check the float chamber/carb and petrol pipes for leaks and splits in the engine bay. It would soon evaporate with the heat once hot, so you might not see any drips.
Check the fuel line under the car too.
Are any gaskets blowing? Manifold? Exhaust? this wont be helping if there is.
Other then that, its having a play with the carb (if the timing is correct)
Posted 03 January 2007 - 10:11 AM
Plumb this in, get car to operating temperature and check the mixture levels, probably your fueling too high or its the fact that you have more stuff turned on like heaters, lights etc.
Posted 03 January 2007 - 09:36 PM
Too large a gap could mean the valves arent opening and closing when they should. Dont try to correct this by compensating with timing adjustments. Before timing adjustment always ensure the clearances are set correctly first.
But this shouldnt make a big a fuel difference as you are explaining, but it will make a slight difference i guess.
Posted 03 January 2007 - 09:59 PM
Posted 04 January 2007 - 01:32 AM
Posted 04 January 2007 - 02:05 AM
what engine do u have olly draper?? 1275?? 998?? is it injection??
eloo, i knw how you feel about the petrol, i have a tuned 998, thats jus drinks teh petrol, i do rag the enigne to get the most out of it, which prob dnt help, but i jus thnk, you gotta, i had a major problems, b4 hand though, and i found that fitting a new carb did the trick, my fuel economy rose, and performance improved, jus a though to try it
Posted 04 January 2007 - 05:20 AM
Posted 04 January 2007 - 06:04 PM
Of the two little connectors, it's the left one, directly in the middle.
Also, the engine bay smells quite a lot of petrol, and when it's running the bay also starts to smell of exhaust fumes. Is that normal?
Posted 04 January 2007 - 06:11 PM
I've also got an LCB and K&N cone filter too plus a slightly richer needle (BDP instead of the standard BFY), but to date i've not had it set up on a rolling road to get it all optimized and i've only ever got it crypton tuned by a mobile tuner who does a pretty good job.
Mind you if I drive it sensibly I've been able to get as much as 50mpg on a good run and you should be able to achieve similar results too!
Posted 04 January 2007 - 08:00 PM
Whilst the tube on the right has the breather hose attached and the black rubber hose runs off to a Y piece with one hose attached to the crankcase breather (on the left hand side of the engine, just above the clutch housing) and the other hose attached to a breather on the right hand side of the engine, close to the radiator.
So from what you say it looks like your carburettor isn't connected up properly and isn't venting to the engine breathers?
If thats true then it needs to be sorted soon and I've also got a thin black plastic hose running from the front of my HIF44 carb to the little unit on top of my distributor. Yes it's the vacuum hose.
No it's not and it's because your engine breathers aren't connected.
Edited by taffy1967, 04 January 2007 - 08:05 PM.
