Cherry Bomb Exhaust ?
Posted 31 December 2006 - 10:46 PM
Now, does anyone know which type of cherry bomb unit I need to buy, preferably with a nice tail-end. And what else would I need to buy so that I can actually fit it to the exhaust system ?
I will post pics of my car soon, thanks !
Josh.
Posted 31 December 2006 - 10:48 PM
I think theres a cherry bomb on mine, somehow its been stuck onto the original standard pipe and then a chrome trim added to the exit.
Its coming off for a full RC40 system
Posted 31 December 2006 - 10:50 PM
Posted 31 December 2006 - 10:54 PM
The RC40 gives best performance increase when fitted.
A stage 1 kit for a 998cc engine (RC40 exhaust, freelow manifold, inlet manifold, air filter, needle and fitting kit) is around £150. This is said to give 20% increase in power (when rolling road tuned correctly)
You can buy it in various forms from www.minispares.com
**A RC40 back box will not fit a standard exhaust. You will need an adaptor/magic pipe or a full system**
Posted 31 December 2006 - 10:56 PM
Posted 31 December 2006 - 11:04 PM
I loved my last 998cc as i had it tuned and it run great. My current one needs a tune, but its coming out for something a little faster (but i am now 2years older)
Yes, your insurance will probally go up. So factor the cost into it. Plus a rolling road tune session is around £60-100 (optional) but defaintly worth doing if you want to make the stage 1 kit power increases and save some petrol.
Welcome To TMF by the way, enjoy driving your mini.
PS. When increasing engine power etc, it is advised you have the braking power capable to stop the thing efficiently. You will have 8.4" brakes and 12" wheels as standard on a 1991 model (unless its been modified/changed)
All the best.
Edited by Jordie, 31 December 2006 - 11:07 PM.
Posted 31 December 2006 - 11:37 PM
you will get the noise you want + a bit more power
Posted 31 December 2006 - 11:39 PM
I think i'll try getting used to the car first as you said, I guess I could temporarily get some sort of exhaust to maybe make it look a bit better + add as nicer sound, as at the moment its just the standard pea-shooter jobby.
Any recomendations ?
Posted 01 January 2007 - 12:23 AM
Posted 01 January 2007 - 03:02 AM
Too much noise?
Happy new year anywayaaa.
Posted 01 January 2007 - 03:31 AM
Posted 01 January 2007 - 12:23 PM
But the best i've heard come from Maniflow, Playmini, or a proper 1.75" RC40.
Posted 01 January 2007 - 01:33 PM
In the mean time, make sure brakes are in perfect working order (buy better discs and pads)
Suspension is in working order: buy better dampers, hi-los and HD Tie Bars as a must.
This means that whilst you might not be able to go faster, at least you will be able to stop and go around corners, and wont affect the insurance.
Straight after that, unless you can afford to do at same time: Headlights not candles, electronic ignition kit from MiniSpares (ignitor kit fits inside the dizzy cap).
Then once your Mini is running sweet and stops, corners, etc get the stage 1, get it rolling road and make the most out of it all.
(just what i would do with my first Mini, and something i wish i was advised to do when i first started out)
Posted 01 January 2007 - 08:42 PM
Just got one with the rc 40 pipe - but only wanted pipe to go onto the rc 40 back box - bus was thinking about putting the cherry bomb on lol
however wont now
Posted 01 January 2007 - 09:08 PM
