ady zr1!
217 replies to this topic
#121 adyzr1
adyzr1
  • 257 posts
Posted 01 March 2007 - 03:22 AM
Hi guys,
thanks for all the info and efforts!! tis why i love this forum.
what koss is saying is correct, that basically if the rack is mounted behind the front axles and on the bodyshell (which it is) that it is behind the "crumple zone" it may be exempt to displacement also the other jargon means you must have a padded steering wheel.
like Koss says it is true that the column is designed to move away but if this cant be proved one or a combination of the three things below must be done in order to satisfy sva
1- universal joints (the brakage of the column will fold in a crash instead of coming at you )
2- sliding rods (ooooooooh mmmaaaaatttttrooon!) basically two telescopic rods that slide within each other
3- collapsible column/steering wheel boss (many of the steering wheel manufacturers make these such as omp, sparco etc
in my situation the standard mini column does not fit with the curley dash so i am forced to alter the setup so i am going with options 1 and 3 above.
alburglar i will post some pics soon as i can .
Edited by adyzr1, 01 March 2007 - 03:33 AM.
#122 adyzr1
adyzr1
  • 257 posts
Posted 08 March 2007 - 02:42 PM
Just a quick update, finally managed to finish my steering column , as i said before the curley dash wouldnt fit with the standard column setup :proud:
First of all i hung the column in place with tiewraps and sat in the car and zipped the tiewraps til i was happy with the position.
Then i made a cardbord template to extend out from the mini's crossmember, bolting to the original column mounting point
then i got some 3mm steel plate and copied it.
Edited by adyzr1, 08 March 2007 - 02:45 PM.
#123 adyzr1
adyzr1
  • 257 posts
Posted 08 March 2007 - 02:47 PM
The bracket was then bolted in place with angle iron on the other side to spread the load
Edited by adyzr1, 08 March 2007 - 02:50 PM.
#124 adyzr1
adyzr1
  • 257 posts
Posted 08 March 2007 - 02:54 PM
This is the finished job , i added tubular steel bracing and welded a bracket to locate the bottom of the column.
This should keep the sva man happy , as it now offset with universal joint and collpsable boss :proud:
Edited by adyzr1, 08 March 2007 - 03:05 PM.
#125 adyzr1
adyzr1
  • 257 posts
Posted 20 March 2007 - 04:27 AM
quick update,
fitted my sound insulation and front carpet , the sound insulation is camping roll mat!(for sleeping) it only weights 2.8 grams for a 2metre roll x 550 ,you can buy it in different thicknessses aswell (i got 12mm)
Edited by adyzr1, 21 March 2007 - 04:15 AM.
#126 adyzr1
adyzr1
  • 257 posts
Posted 20 March 2007 - 04:30 AM
fitted front carpet so dash could go back in, also fitted switches and digidash, going to fit gear lever extension 2morro.
Edited by adyzr1, 20 March 2007 - 04:34 AM.
#127 Monte Busa
Monte Busa
  • 681 posts
Posted 20 March 2007 - 05:10 PM
Hi there Ady.
Your dash is starting to look a little bit like mine!
Cheers,
Aric
#128 adyzr1
adyzr1
  • 257 posts
Posted 24 March 2007 - 06:59 PM
finished the gear extension today, basically the curley dash covered the z cars gear leaver , so i made an extension and handle
Edited by adyzr1, 24 March 2007 - 09:41 PM.
#129 adyzr1
adyzr1
  • 257 posts
Posted 24 March 2007 - 09:36 PM
.........key hidden under dash, ^_^ the small red button is a push start
#130 dean_chad
dean_chad
  • 733 posts
Posted 24 March 2007 - 10:29 PM
ady it looks great. I can just about see your gear lever, what did you fabricate it out of?
Dean
#131 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 24 March 2007 - 10:33 PM
It looks like the bar end from a mountain bike????
Real neat dash
Could you have moved the gearstick back and ran a shorter cable ??
#132 adyzr1
adyzr1
  • 257 posts
Posted 24 March 2007 - 11:51 PM
couldnt move gearstick back because of the handbrake lever.
it is from a mountainbike! going to reduce it in size and fit an anodised blue "stubby" bar end in a vertical position, rather than horizontal.
#133 Tomm
Tomm
  • 2,462 posts
Posted 02 April 2007 - 12:39 AM
HAHA love he Eastern EA30's which you have used as a extension on the gearlever!
Very nice thread mate, good luck! I will be watching this one very closely!
#134 adyzr1
adyzr1
  • 257 posts
Posted 03 April 2007 - 08:52 PM
[quote name='tomm' date='Apr 2 2007, 01:39 AM' post='493161']
Well spotted Tomm!
Car is nearly finished just sent paperwork off for sva!
got to pull my finger out just incase it is sooner than expected :(
#135 Mini Man Dan
Mini Man Dan
  • 1,299 posts
Posted 08 April 2007 - 08:03 PM
Just read your whole project thread and it really has come on. Looks great. Can't wait to see it on the road or should i say hear it lol.
Thanks for the lift today mate really appreciate it!
Dan
