Well, finally, sorted the problem!
What a ball-ache it was to get there tho!
Malc called me up this morining having had someone else go to his to have a look. They had wound the dizzy up to 60deg advance, which made the initial 3000rpm much smoother, but in theory, it should be pinking its nuts off - but it wasnt. It lead them to believe that either the dizzys ********'d or the cam timing is way out.
So i went to malc's with a new dizzy and ignition system, thanks to oli. Tried it first, as that was easiest, and it didnt really get any better. So, instead, we decided to limp the mini home, tear it apart, and re-check the cam timing. Dispite the fact that i'd already checked it after last time it was out. To make sure it wasnt me doing anything wrong, oli checked it, and found it to be right on the mark, 105.75.
Decided to ring southam mini centre and see what they rekoned on the subject. Their advise was the 1.5 rockers where too much. Confused me a little, as the car came with 1.5's, and i didnt want to loose my top end power. But, at this point, we didnt have a lot to lose, so we but its back together with standard sintered rockers.
And now...... its goes, and it REALLY does go! Like a rocket! And to be honest, i dont think i've lost anything on the top end... i know its a fresh engine an' all, and the weber hasnt even been re-tuned since the 1.5's have come off, but i couldnt resist... but it got to 9000rpm in first before i changed and was still pulling
Think a bit of self control will be in order for a while, but knowing what it's now gonna be capable of... its just imense.
Doesnt feel like a mini engine, its not as brutal as a 1380, its just an awsomly smooth power delivery, from somewhere between 3-4000 rpm... till whenever you decide to change gear
Dunno what to do about these 1.5 rockers now
If anyone wants them, they cost me £260 new, and i'd like something close to that, bearing in mind the only mile's they've done have been on the rolling road. When i spoke to southam, they did say, they are by far the best you can get, its just a shame they are a bit overkill on my motor. I do want some proper 1.3 rockers tho, as sinterd ones are actually more like 1.2-1, and i dont think they're gonna last too long. I'm gonna speak to MED first and see if they can do anything to adapt them, but if anyone has any sensible offers, send me a PM.
Soz bout the essay, think it might be benifical for some to read tho, as 1.5's get talked about a lot, and this is an example where it seems, with the wrong cam, they are useless
dammit! should have kept that lame ass 286scatter!
Tra tra
