Project JetBLICK
#391
Posted 15 December 2007 - 09:09 PM
How much do u wreckon your going to get done, when u bk to uni?
#392
Posted 15 December 2007 - 09:12 PM
#393
Posted 18 December 2007 - 10:47 PM
looking good!! make sure you keep the dremmel away from this one!!!!!!
Funny u should say that, i'm breakin it out tomorrow for 'adjustment' to the inside of the block...
Anyways, progress is guuud
Sunday i spent repairing the radius arms, i managed to do them both in a day which was good. So with that out the way i started the engine on Monday afternoon by putting the head back together. Today i've done a test build of the block, to check all the clearances and stuff. So basically built up the whole thing as i would normally, timed the cam in, then put the head on with rockers to check to make sure i'm not gonna have trouble with exhausts valves hitting pistons, following a conversation i had with nick swift yesterday. I called him up for the timing figures for his cam, and he mentioned that i should check the clearance because of the small chamber size then get back to him with the figures... very helpful chap
Also while doing this i found the last cam lobe on the oil pump end is fouling the block casting where theres a little lump of metal left, so the dremels coming out 2morrow before i re-build it
After doin the block, i started the stripping the old mainshaft of 2nd and 3rd, thinking that i'd build the box up tomorrow, turns out it didn't take very long at all and the whole box is now finished more or less. Had to measure up the gaps of various shims that i'm gonna see if i can get from the engineers tomorrow.
I did make a massive schoolboy error, forgetting that the transfercase from the 1071 was pre-A+ with the smaller idler bearing, and my drops and gearbox are A+, which means tomorrow i've got to take one of the 998's transfer cases to the engineers to get it steam cleaned and pop the old bearings out
All in all its goin well and i anticipate that the motor will be nearly finished by tomorrow and in and fired up by the end of the week. Unfortunately tho, theres a few small bits do do for MOT that i dont think im gonna get done in time for an MOT on friday, so i'm gonna have to wait till after christmas
Nite y'all
#394
Posted 18 December 2007 - 10:56 PM
is it just a casting error on the block then? i take the blocks 2nd hand how come previous engine builder didnt know about the casted lump or would it be because of the differing cam
good luck with getting mostly built then!
#395
Posted 18 December 2007 - 11:03 PM
#396
Posted 18 December 2007 - 11:09 PM
#397
Posted 20 December 2007 - 11:38 PM
Tomorrows the last chance because after tomorrow they're closed till january 3rd.
I gotta go again tomorrow so they can sort my baulk rings.. see here.. http://www.theminifo...x...c=66760&hl=
So gearbox has gotta come apart again
Nevermind, i'm not really in too much of a rush anymore, since the RR/MOT place aint gonna be open now for a week. Just hope i dont need any more bits from the engineers
Soz for the lack of piccys, theres not much to see to be perfectly honest all looks best when its all together.... so i took these
By the way, thanks to whoever put the 5star thingy on my project, i've no idea how you did it (unless its a moderator thing?), but i appreciate it thankyou
Dan
#398
Posted 20 December 2007 - 11:44 PM
Looks smart mate, as I said at yours the other night, I can't wait to see it down the track
#399
Posted 22 December 2007 - 11:34 PM
Well, its practically done now... well, that gearbox ent getting un-bolted anytime soon anyway! I've used allen cap 5/16 bolts and my god they are a PITA to do up! If you think doin up your gearbox bolts with a spanner is fiddly and time consuming, try it with an allen key!
Only a few things left now, gotta sort the rocker cover out for the new breather system, block some of the holes and then make some bigger ones
Unlike previous pics... all the bits are actually in there now
Probs gonna have to wait till January now tho to get it on the road, as the engineers dont come back till the 3rd and they're the ones who gonna sort out my RR session so that i get a top notch job, woop
by the way if anyones ever looking for engine work to be done in the worcestershire/bromsgrove area i cant recomend BES enough, they've been so helpful, even so far as lending me a couple of deep sockets over christmas so i can do up my head studs (stupid ARP 'star' drive nuts)
Ta Dan
Nite y'all
#400
Posted 24 December 2007 - 03:27 PM
You sound like you really know your stuff sir!
I'd be terrified of ballsing an engine up if I built it myself :|.
Looking forward to seeing it on the road
#401
Posted 24 December 2007 - 05:02 PM
#402
Posted 24 December 2007 - 09:00 PM
#403
Posted 24 December 2007 - 10:07 PM
by the way i keep missing you wen ur on msn... i could do with a hand lifting the motor in mate, just a 5 min job, dont need the crane or nowt.
As for knowing my stuff deathrow, i dont really, u just gotta talk to the right people when getting advise
#404
Posted 25 December 2007 - 09:20 AM
Yeh, no worries mate, giv us a ring when u want to do it, i can rob ur strobe again lol, because we had her too advanced again wen i took her down the rollers, so i wana check bluey to, dont wana nail the pistons on that on too!
#405
Posted 25 December 2007 - 09:49 AM
