Riiiiite, this last week i've also, fitted the headlining - that was a PITA job i never want to do again! its not perfect i'll be honest, but i did fit it with 3/4 of the rollcage still in, and since i took the photos it has tensioned up a bit more and some of the wobbles have come out.
Also finished the rear of the car.. so the rear wiring loom was done, rear passenger arch went back on, the fuel tanks back in, boot back on and the hole was drilled for the reverse light. Only problem is i do not know what size the nut is that is on the reverse lamp, the reason i got it cheap was because the nut was missing... i'm starting to find out why
The front is also back on, with new straps, lower securing pins and the contact lenses
Every single wire is being replaced in the car, and all the looms are pretty much complete, all thats left to do is wire teh alarm into the dashboard harness. I've re-done this loom so that it is now idiot proof, and dead simple should anything go wrong. Theres a loom for the back, a loom for the dashboard, a loom for the engine and a loom for all the lights on the flappy front. The two front looms have connectors at the bulkhead, so things can be taken apart quickly, and every system in the car has its own separate fuse, i.e. a fuse for the indicators, a fuse for fuel pump, a fuse for sidelights... etc etc
Ermmmm.. thats all for now... hopefully the car should be back on the road near the end of this week... some bits will be left unfinished, because the main priority is to get the car back on the road so that i can get back to work, earn money, and finish all the little bits that need doing still.
Ta, Dan
