Out with the A and in with the K
38 replies to this topic
#16 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 12 December 2006 - 12:57 PM
sleeved driveshafts?... what are they?
anything like cut and shut ? :thumbsup:
#17 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 13 December 2006 - 12:59 AM
similar, slightly stronger but my main concerns would be the balance and the strength of the weld!! definate arc weld in my books!! dont think mig would have the penetration to make it strong enuf!!
#18 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 13 December 2006 - 07:18 AM
It depends on the "amps" rating of the welder , if sleved shafts are done properly they only require glue or tack welding , welds too deep into the driveshaft will weaken the shaft
from what i have read you turn down the biggest shaft to the diameter of the thinnest then you mill a step half way into each about 25mm long , a sleve is made so both ends press fit in using heat (they overlap inthe middle) this can be held with engineering glue or tack welded and is strong enuf for 200BHP
sorry if this explanation does nt make sense , a better one can be found on the 16v forum
#19 fikus01
fikus01
  • 1,910 posts
Posted 13 December 2006 - 08:53 PM
that does make sense!!
i think this is roughtly corect but i was referring to arc welding because mig melts the metals together thus giving you a thin spot across the weld!! arc and tig dont!! that add material to bridge the gap.
it makes sense that they would be press fit!! when u mentioned sleved i immediately thought BODGE but now you say you're doing it properly with interferance fit im sure thats guna be more than strong enuf!!
#20 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 14 December 2006 - 01:40 AM
I think you'll find mig adds material as well!!! It just comes through the torch (its the welding wire!!).
#21 fikus01
fikus01
  • 1,910 posts
Posted 14 December 2006 - 06:44 PM
sorry i know mig adds material too but as far as i was aware it was purely to get things going, more like a conductor that helps get the original metal flowing!!
#22 directorydaz
directorydaz
  • 385 posts
Posted 28 December 2006 - 06:21 PM
Just a little update...
Frame one was made yesterday afternoon.... and then fitted to the car JUST...
lots still to do..
#23 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 28 December 2006 - 06:24 PM
Sexellent news mate!.. :w00t:
#24 directorydaz
directorydaz
  • 385 posts
Posted 28 December 2006 - 06:27 PM
lots left... but it is sat on its wheels.. something a lot of projects dont do for a long time!
#25 directorydaz
directorydaz
  • 385 posts
Posted 04 February 2007 - 01:10 AM
quick update..
its been in and out like the okie kokie, frame is now on its 3rd generation, first temp shafts for sizing have been cobbled and it goes back in next week for final trail with everything in, Shafts, tiebars, wheels, brakes the lot to check for catching and clearance, this will get pushed about and checked running lock to lock etc.
if all well.. new shafts will be send off to be made, and i will get it bolted in, front mounted and will start on wiring and exhaust... leaving the plumbing till last..
#26 Red Staff
Red Staff
  • 17 posts
Posted 07 February 2007 - 09:53 AM
Sorry for sounding stupid but what do you guys mean when you say A engine and K engine.
#27 nag1_uk
nag1_uk
    Ring Runner 2005
  • 227 posts
Posted 07 February 2007 - 10:17 AM
A as in a the "A series" ie the normal mini engine.
K as in the "K series" the normal engine from newer rover cars. found in the metro, rover 100, 200, 400, 25, 45, ZR, ZS, mgf, MGTF etc.
Mike
#28 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 14 February 2007 - 11:33 AM
And S1 Lotus Elise's
#29 fikus01
fikus01
  • 1,910 posts
Posted 15 February 2007 - 08:13 PM
end early s2 elises!! doesnt make them any better tho i do have a sweet spot for the k-series!!
#30 directorydaz
directorydaz
  • 385 posts
Posted 28 March 2007 - 10:47 PM
Now forsale...
Very reluctant sale
http://www.theminifo...view=getnewpost
