power steering
21 replies to this topic
#1 dread
dread
  • 38 posts
  • Local Club: trinimini
Posted 11 December 2006 - 01:24 PM
has anyone upgraded their Mk3/4 to power steering?
how to go about this project?
which car would the parts be coming from?
thanks
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 December 2006 - 03:47 PM
I think you can do it with an electical power steering mechanism, but what from, I don't know... no mini was ever produed with PS
#3 dread
dread
  • 38 posts
Posted 11 December 2006 - 04:03 PM
thanks man
#4 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 11 December 2006 - 04:44 PM
there is a company called minitastic that is just about to release a Power Steering Kit! they have developed it over the past few years!
#5 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 11 December 2006 - 04:50 PM
Its not going to be very cheap though!
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 11 December 2006 - 04:58 PM
i guess if you have a K series/V tec conversion using a metro front subframe then the metro stearing rack would fit
#7 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 11 December 2006 - 05:03 PM
I think I have seen a Vauxhall corsa setup used
#8 dread
dread
  • 38 posts
Posted 11 December 2006 - 06:00 PM
this might be a stupid question but i must ask:
can the steering from the BINI work?
if so how much would that conversion cost?
#9 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 11 December 2006 - 06:10 PM
mgf tf's had electric power steering!! im sure there is a way to adapt a sensitivity switch to the cpu on the column so that it could be adjusted by the driver!!! i think the column is slightly longer than that of a mini tho but not necesarily a bad thing!!
#10 GraemeC
GraemeC
  • 7,438 posts
Posted 11 December 2006 - 06:33 PM
I'm looking into this at the moment and have a coupe of Corsa columns with electric PS in the workshop. However the spline forms are differnet between Corsa and Mini (not suprising) so its not a bolt on conversion.
So - does the MGF use the same splines as a mini? I know the top of the column is the same as an MPi and I don't believe the MPi had a different rack (apart from Sportspacks) so would an MGF column fit a standard mini rack?
#11 Big_Adam
Big_Adam
  • 7,435 posts
Posted 11 December 2006 - 06:39 PM
wood and pickett do powersteering give them a call.
#12 fikus01
fikus01
  • 1,910 posts
Posted 11 December 2006 - 06:55 PM
late metros/mgtf's have smaller spline arrangment but using a metro/mgtf rack wouldnt be such a bad idea, would make it less dangerous because it will be less twitchy!! minis 2.7 turns is fine with no power assistance but with it a sudden steering movement could be fatal!!
#13 dread
dread
  • 38 posts
Posted 11 December 2006 - 07:27 PM
good point.
i think i might just change my mind and forget about the PS and use a bigger steering wheel. :thumbsup:
#14 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 11 December 2006 - 07:38 PM
I've heard that Somerford Mini Specialists do the conversion too?
Somerford Mini Link
#15 Jobu
Jobu
  • 508 posts
  • Local Club: 16vminiclub
Posted 11 December 2006 - 07:41 PM
:thumbsup:
