Monty the Rwd R1 engined tarmac eating Minus
654 replies to this topic
#76 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 07 December 2004 - 02:04 AM
How easy is it to fit a sump guard and is it worth it?
it is a bit of a pain in the arse but well worth it, especially on a lowered car.
Most of the sump guards I have seen have the same set up:
Two holes to be drilled in subframe at the front and two at either side at the rear of the subframe. trouble is, if you line the gaurd up dead centre, then the holes at the rear have to be drilled through a vertical bit of the subframe. so you either have to widen the holes on the sump guard or offset the guard slightly.
#77 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 07 December 2004 - 02:07 AM
have now had a look and the car does have adjustble ride height. So just need some adjustable dampers to match
#78 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 07 December 2004 - 02:11 AM
and also cased out getting a reversing light sorted. Just need the switch that screws in here at the side of the rod exchange, and then feed the wires back to my mates mk4 rear lights.
You can see the round opening on the left hand side of the box in this picture
#79 Jackman
Jackman
  • 4,053 posts
Posted 07 December 2004 - 01:49 PM
Well i think ill leave it, my car is not lowered or anything so i dont think its worth it yet. Thanks anyway
#80 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 07 December 2004 - 03:28 PM
hey alburglar
have u got any pics of your dash, im buying a curley carbon dash after christmas and i'd like an idea of how yours fits, and if its a good fit
thanks mate
#81 Jackman
Jackman
  • 4,053 posts
Posted 07 December 2004 - 04:43 PM
Its on page 5
#82 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 07 December 2004 - 05:38 PM
hey alburglar
thanks mate
I'll take some specific dash photo's when my magnolia dials and shift light turn up after crimbo. Hint hint santa
#83 YoungUn
YoungUn
  • 488 posts
  • Local Club: F.A.B.M.O.C
Posted 07 December 2004 - 05:48 PM
how much are curley dash's and where do you get them from?
AND also.. what is the ride height?? looks pretty low on the pic on page 5 of the sumpguard
#84 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 07 December 2004 - 05:55 PM
www.curleyuk.com
150 to 325 quid
#85 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 07 December 2004 - 05:57 PM
Dunno what ride height is.
It is set at just enough to clear speed bumps at 1 mile an hour.
#86 mini_ron
mini_ron
  • 331 posts
Posted 07 December 2004 - 06:53 PM
mmm thats a sexy minus!!
aaron
#87 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 December 2004 - 11:34 PM
I know you probably know this already, but what you posted above sounded a bit odd so:
Adjustable dampers are different to adjustable suspension, they aren't adjustable for stroke (to accomodate lowered cars) but are adjustable for bump/rebound levels (basically how firm they are). What you might need is dampers for lowered cars, which have about 1" less travel. But there's no hard and fast rules about when they are needed.
Also you might need the modified front top shock brackets for lowered cars, these keep your dampers in a more vertical position than the standard brackets do when the suspension is lowered and move the damper up a little.
#88 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 08 December 2004 - 10:40 AM
LOL.
Yes dan, I did know that. :rolleyes:
I want new adjustable dampers as my current ones are ancient and too harsh. I think because they are standard length koni's, and the car is extensively lowered. So I want new ones so I can set the re-bound to suit me and lowered ones to suit the ride height. Spax, Gaz and proshocks all do ones with both qualities and have an easy method of adjustment.
Thanks anyway though. :lol:
#89 smudgersmb
smudgersmb
  • 210 posts
Posted 16 December 2004 - 05:22 PM
I remember the Minus being in a mag feature. Got it in the house some where but dont ask me to find it :grin:
As for the dash, doing my own which will be avaible after xmas.
Smudger
#90 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 20 December 2004 - 10:47 AM
Yeah I got about 3 copies of that feature. The spec he lists is complete b*llocks tho.
