Monty the Rwd R1 engined tarmac eating Minus
#586
Posted 08 September 2011 - 08:50 AM
Looking forward to seeing the updates.
#587
Posted 17 September 2011 - 01:21 PM
Didn't realiser there was another Z cars close. Would be good to see it when its on the road.
Dan
#588
Posted 15 November 2011 - 10:28 PM
Rear number plate is way too low to be practical it turns out, so I'll be moving that next and then get the bulkhead and some seats in.
Ps Hi dan, just seen your post. How far along are you with yours?
#589
Posted 16 November 2011 - 06:08 AM
Well done you
#590
Posted 16 November 2011 - 05:18 PM
...and yes it was good to get it rolling at last!
#591
Posted 16 November 2011 - 07:30 PM
Simple is often the most effective, good job.
#592
Posted 16 November 2011 - 11:29 PM
#593
Posted 17 November 2011 - 06:29 AM
I also had the usual problem of the electric reverse drawing too much juice and killing the engine, which so many bike engine cars have suffered from. I have had a 2 farad capacitor tucked away for ages now incase I needed it. I'm going to give it a try, Wiring it in between the battery and the reverse motor. Hopefully that will stop the voltage drop when you use the reverse.
Can you tell us more about this? I have given up (for the moment) trying to stop my electric reverse motor "dropping out"
#594
Posted 17 November 2011 - 05:33 PM
Wiring a power cap in is like having an extra battery, the only difference is it can deliver all its stored power very quickly and hopefully this will cure the problem. They use them in large in car audio setups, to stop the headlights dimming when the subwoofers deliver big base. Therefore power capacitors are common as muck, cheap (mine was £10 on ebay) and they are sealed too so can be mounted anywhere.
#595
Posted 17 November 2011 - 06:27 PM
#596
Posted 17 November 2011 - 08:15 PM
#597
Posted 22 November 2011 - 01:35 AM
#598
Posted 28 November 2011 - 08:28 PM
Couldn't drive it yet I have been sorting out the number plate.
Doesn't look like much, but it's an inch higher, should make all the difference as before it had only 3 inch ground clearance. I've glassed it in now, but I haven't taken a pic yet,
Edited by Alburglar, 28 November 2011 - 08:29 PM.
#599
Posted 01 December 2011 - 08:17 PM
Finished
All back together
Edited by Alburglar, 01 December 2011 - 08:21 PM.
#600
Posted 01 December 2011 - 08:20 PM
Had to laugh with the swirled out plate, when your sig shows the full plate lol.
